New Product: Laser Ping Mount
Nice little mount with holes for Arlo or similar, and holes spaced for servo horn for a LaserPing DAR!
https://www.parallax.com/product/725-28041
Have you played with the LaserPIng)))? It is fantastic.
I would have to say that the etching and millwork cutout are unnecessary and surely drove the price up, but it does look nice
I must admit that it is a nice looking part, but I would be willing to bet that it would work perfectly fine without the recess or "engraving".
Nice job Parallax.
Just pulling the chain a little
Collector's Edition product setup right there, Jim.
I set up all three Laser PING))) at 3.3 VIN, disabled the translator, and did a direct input to Pins 0,1,2. It runs the Stingray Demo program fine.
Whit. It will not run your 1.5 demo. Are your PINGs 0,1,2, (right,center,left), when looking from the back wheel?
Let me know if this helps!
I see thee errors of my ways.
I see now that Pings are setup for P1-3 in your setup
PRI Pings | i, Ticks '' Runs in a seperate cog 'continuously read in Ping distances repeat repeat i from 1 to 3 Ticks := Ping.Ticks(PING_PIN + i) Distance[i] := Ticks Ticks /= 104 Ticks <#= 96I had it set up for P0-P2 based on the original Ping with Stingray program.
All is good with the world.
