$2 Clock Kit
12345679»
  • TorTor Posts: 1,977
    DAB country here. FM has been switched off. Big energy-sucking block of a radio. No sleek ultra cheap running-for-months radios anymore. AC, or charge every day. It's like going sixty years back in time. Worse.
  • ercoerco Posts: 19,456
    edited 2018-05-16 - 21:34:23
    So you guys must replace all of your car radios too? Who thought THAT was progress?
    "When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
    - Pablo Picasso
  • DAB, is there for minimise frequency bandwith.
    Shrinking frequency, not energy.
    Everybody wants everything wireless.... WIFI, MOBILE, REMOTE, 3G,4G,5G, Sat TV, GPS ....
    I can confirm the quality is much better than FM.
    I listen already for several years, even my car has standard BAD
    It is an European decision.
  • Ltech wrote: »
    Follow the money!
    Ltech wrote: »
    FM is not wireless?
    Ltech wrote: »
    I want it small and I want it energy efficient and I definitely do not need an audio quality outdoors and in the car that is by dimensions better than my ears!
    ◁ propeller-wiki ▷ ◁ FastSpin ▷ ◁ DK-E ▷ ◁ :-D ▷ ◁ Stay OmmmmmmPtimistic! ▷ ◁ No Source – No Go! ▷ ◁ Help Spin at RosettaCode.org ▷ ◁ Why Asimov's Laws of Robotics Don't Work ▷ ◁ DNA is a four letter word. ▷
  • erco wrote: »
    NOW... Real men build their own $2 FM receivers! :) :) :)
    https://www.ebay.com/itm/192119861885]
    Couldn't agree more, ercoman. I liked that kit so much I bought two more.
    1976 x 1482 - 304K
  • ...or one I²C tuner per ear?
    —▷ https://www.ebay.com/itm/253112898517
  • Couldn't pass up the opportunity to mention two more great kits. Of all the FM transmitter boards and modules that are available, these are my two favorite. They are closely related to each other. Main difference is that one uses a variable capacitor for tuning. The other uses a slug-tuned inductor. The former board also has a pot to adjust modulation level. The latter has a preset level that is very well chosen.
    Both of these boards switch between the onboard microphone and a 3.5mm aux in port. I love that feature because more often than not I'm transmitting data, not voice or music.
    They are more stable than most wireless mic circuits because there are three separate stages: audio amplifier, rf oscillator, and rf amplifier. Also, the last two stages use real rf transistors, not 2N3904 or PN2222.
    https://www.ebay.com/itm/FM-Wireless-Microphone-DIY-Kits-Suites-FM-Radio-Transmitter-1-5-9V-76-108MHz/332263126483?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
    https://www.ebay.com/itm/DIY-Kit-88-108MHz-FM-Transmitter-Frequency-Modulation-Wireless-Microphone-Suit/222791624095?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
    1453 x 1040 - 260K
  • jmgjmg Posts: 13,560
    David Betz wrote: »
    I have to say that the people who sell this $2 clock kit are very responsive to support requests. As I mentioned earlier, they sent me the source code for the clock and they sent me a new MCU chip when my clock didn't work. After the new MCU chip didn't help the problem they offered to send me a new kit or refund my money. I'm not sure what went wrong with my kit assembly but they are certainly trying to resolve my problem. That's pretty amazing for a $2 kit!
    Did you ask them if they tested the MCU they sent ?
    Can you read those parts yet ?
    Looks like you can read without needing 12V : just RST=H, and the internal counter feeds bytes out on P1, from 0000, & pulse Xtal pin, to advance.
    I think secured reads 0xff, so the very first byte should be < 0xff, eg 0x01 0x1D 0xff..
    Programming is only slightly more complex : RST=12V and Erase pulse of 10ms, then PGM/Busy handshake as you apply bytes & pulse Xtal
  • Heater.Heater. Posts: 21,213
    edited 2018-05-16 - 21:20:07
    erco,
    Wow, never heard of DAB before!
    What?
    How amazingly isolated from the rest of the world America is.
    Digital Audio Broadcasting has been around for ages. Now it has gotten so bad that there is no traditional AM or FM broadcasting in Norway. Drive there and your car radio has nothing to receive.
    No, they want you to buy a DAB receiver.
    Thing is, cellular coverage is so good everywhere, hence internet access, that who needs an AM/FM/DAB radio anymore? Just play the tunes you want from the net anyway.
  • In the UK, DAB broadcasts (not DAB+ because we were early adopters) are worse quality than FM - and sometimes in mono so that they can cram even more useless stations into the available bandwidth.
    Besides the problem of the receivers being much more power hungry - so battery powered ones eat the batteries in a day or so - there is also an unpredictable delay which means that the time 'pips' are no longer an accurate way of setting clocks. If you have an FM radio and a DAB one both receiving the same station (FM hasn't been switched off here, yet) then the DAB one is usually a couple of seconds behind the FM one, but sometimes more - maybe it even varies from one receiver to another depending on how their decoders are programmed and how fast their processors are.
    Nice work, K2! You're doin' this hoarder proud!
    - Pablo Picasso
  • jmg wrote: »
    David Betz wrote: »
    I haven't been able to find any software that works with the programmer that I purchased. I have 10 spare MCU chips though so if I can ever put together a programmer+software I should be able to experiment with the source code they sent me.
    Did it go unnoticed what DAB is backwards?
    - Pablo Picasso
    edited 2018-05-16 - 22:26:35
    David Betz wrote: »
    Maybe you can port something like this to run on a Prop ?
    Ardunio 89C2051 programmer
    AT89C2051 specs 5V +/-10% during pgm, but looks to have TTL levels on all pins, and light pullups, except for RST and XTAL1, so should P1 connect ok ?
  • jmg wrote: »
    David Betz wrote: »
    I'm sure that would work but I was trying to avoid having to build my own programmer.
  • erco wrote: »
    No.
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
  • kwinn wrote: »
    No.
    This is particularly funny coming from a Canadian. :-)
    Note To Forum Police: This is not a put-down of Canadians! What you may not know is that Canada had a 10-year experiment with DAB. kwinn ought to know better than most what DAB spells backwards. Sheesh!
  • Explanation received.
    Infernal Machine
  • K2 wrote: »
    kwinn wrote: »
    No.
    I did spot the backward spelling in the original post and passed it off as the typical typo that is fairly common on this or any forum. When I read your post I was not offended, only curious to know why it would be particularly funny for a Canadian, so thank you for clearing that up. Obviously I did not pay much attention (actually none at all) to the DAB experiment.
