Measuring 69 khz RC Oscillator Circuit With Parallax USB Oscilloscope — Parallax Forums
microcontrollerusermicrocontrolleruser Posts: 1,194
edited 2018-05-09 18:11 in BASIC Stamp
It's for a PIC16F84A.
T circuit. Connects to OSC1.
100pf cap from 0v to T
100K ohm resistor from 5v to T
T goes into OSC1
Where do I connect the Lead 1 and ground on the circuit please?
  • This is what it looks like.
    Anybody know how to adjust the scope to make it right size?
    556 x 545 - 84K
    edited 2018-05-09 18:57
    SX28 is a PIC16F57 Clone
    No it's not. It's a much faster enhancement of the PIC architecture. A "clone" implies that it's identical. to the PIC.
  • microcontrollerusermicrocontrolleruser Posts: 1,194
    edited 2018-05-09 19:38
    Argue with the bunch on PIClist.
    I pretty much figure they know what they are talking about.
    I am attempting to use a black version Parallax USB oscilloscope.
  • Argue with the bunch on PIClist.
    If you can not back that up with facts, you will be asked to delete that quote.
    edited 2018-05-09 20:10
    Publison
    Oh you caught me cutting corners again!
    Understanding signals book version 1 I'm studying.
    I need to go back to testing the blinking LED with Stamp like the directions say.
    Then it tells you how to make adjustments.
    Can anybody tell what frequency the RC circuit is producing?
    I can slow it down swapping in 220 and 330 K ohm resistors for 100 K ohm.
  • 'If you can not back that up with facts, you will be asked to delete that quote.'
    Here you go.
    http://www.sxlist.com/techref/ubicom/picreplace.htm
    'SX processors have been used to replace PIC 16C57's and 54's useing the .hex file from MPLab '
    You can program a SX28 with MPLAB and a little effort.
    edited 2018-05-09 20:33
    That does not make it a clone. A clone is an identical copy. But I see you changed your statement. Thanks.
  • You're welcome.
  • The purpose of the 29 khz oscillator is this.
    RC circuit is 'standing in' while we wait for our crystals to get here.
    The book uses a 32 khz crystal.
    There are two delays in the header file you can call. 1/2 and 1 second.
    With the 32 khz crystal you only have to count 32 times with one loop.
    A 4 mhz delay routine is a lot more code.
  • Is that vertical line really what the circuit is doing?
    Could it be caused by the settings?
  • The vertical line is an axis. The sawtooth tracing is what the circuit is doing
  • 'The vertical line is an axis.'
    What do you mean by an 'axis'?
    edited 2018-05-10 02:56
    I'm assuming that what I think is a vertical line is the same thing you see. I see a vertical dark line in the middle of the graph. That's the Y axis of the graph of the signal over time. The X axis is horizontal and corresponds to time. The wikipedia is your friend (see here)
  • No.I mean the signal.The blue line.
    Okay.Now that you mention it, it is not quite vertical.
    Why is it doing that?
  • The blue line is your signal. The sawtooth shape of it is characteristic of an R-C circuit.
  • 'The sawtooth shape of it is characteristic of an R-C circuit. '
    Great! R-C circuit works!
    Thank you Mike!
  • How do I know what the frequency of this R/C circuit is?
  • The frequency should be in the upper right box.
    What software are you using for the scope? Ver 4.0 or 5.1?
  • Does it look like this:
    781 x 602 - 318K
  • 'What software are you using for the scope? Ver 4.0 or 5.1?'
    5.1.1
    'Does it look like this:' No.
    I do have what you're showing installed though.It starts up and runs in Windows 8.1 here.
    Let me double check it connects to USB scope.
    The frequency will vary depending on the temperature, chip processing parameters, and RC component variations. Typically it will be in the ballpark of 1/(R*C*.5), but it can vary quite a bit depending on the threshold levels of the OSC1 input. In your case that would be about 20KHz, which is close to what your scope image shows.
  • Thank you.
    Table show that combination should result in 71.56khz. Plus or minus 25%.
    You may have already given the reason but why is it @20khz?
  • Why 20KHz? Depends on how it's hooked up and what's on the inside of the PIC. The RC formula gives the time needed to charge or discharge the capacitor, but that depends also on how much current is available from the oscillator and at what threshold it switches. What's the table you're referencing? Does the scope affect the reading?
  • 'Why 20KHz? '
    That is the reading using 100 pf cap and 100 K ohm resistor.
    ' Does the scope affect the reading? '
    First time that has come up.
    How do we find that out?
    edited 2018-05-10 19:49
    It certainly could. And since it's a one-pin oscillator circuit, there's not an alternative low-impedance driver pin to connect the scope to.
    Write an assembly program that toggles an output pin as fast as possible. Then measure the frequency of the pin. Using execution clocks data for each operator in your loop, you can compute what the actual clock frequency is.
  • Phil Here is delay from lesson.
    1366 x 768 - 213K
  • Thank you very much Phil!
    STOP! Please don't write a snippet of code for me to run.
    My plate is full working on this header and blink LED then the next lesson.
    I THINK what you are talking about is like this delay. Rearranged though.
  • Next thing is to change the value of the resistor.
    Will look through resistor tackle boxes for 120, 150 and 180 Kohm ones.
    Then we'll see how the measurements come out.
    Want to graph the results also.
    Also do the R/C formula a couple times and see what results SHOULD be.
  • microcontrolleruser,
    Don't forget that when you put resistors in series that their values add.
    So if you need 150K, you could put 15 10K in series or use 3 50K.
