Radio Transceivers
AwesomeCronk
in BASIC Stamp
Hello, I am trying to find some radio transceivers. The requirements will be that I can send/receive data with a BS2 using SERIN/SEROUT(preferably on seperate Rx/Tx pins), power with 5v, and connect over 20+ ft. By the way, multiple channels would be great! Thank you all in advance!
Where in the heck is Duane Degn? That guy had lots of good projects using the Nordic transceivers. Haven't tried them myself. https://www.aliexpress.com/item/NRF24L01-NRF24L01-Wireless-Module-2-4G-Wireless-Communication-Module-Upgrade-Module/32649820125.html
wiki.seeedstudio.com/433Mhz_RF_Link_Kit/
Unreliable and possibly illegal on that frequency. A win-win!
skycraftsurplus.com/nrf24l01antenna24ghzwirelesstransc.aspx?gclid=CjwKCAjwwuvWBRBZEiwALXqjw1kCtr6oImpOPwXhvbmqseURgjOABUgrfm9aUEYh4uMgpU98L3XFWRoC298QAvD_BwE
https://forums.parallax.com/discussion/133053/nordic-nrf24l01-bs2-code-example
You can use them to connect to your network or just to another device. Plenty of Arduino examples out there for re-programming these devices to do what every you need done with WiFi.
The ESP8266 uses a modified AT command structure for setting up a connection or you can re-program it using Arduino to be a web server.
Digi-Key has the unit for about $7.00.
The parallax unit is a lot more money but it has the power supply on it to work with 3.3v or 5v and the pins work with the BS2.
In either case these units have been used to send data wireless for years now.
I have a Parallax ESP8266 and love it, but am trying to communicate between two stamps, and the ESP does not do that as far as I know.
Jeff Haas.
Thank you, I will look into this. Sounds Promising.
Thank you, both of you.
NRF24L01_at_AliExpress
The X-CTU screen shots and setup part is obsolete but the concepts and BS2 code are still functional.
Test results: http://www.romanblack.com/RF/cheapRFmodules.htm
Antenna is critical: http://www.instructables.com/id/433-MHz-Coil-loaded-antenna
Picaxe buffer chip: http://www.picaxestore.com/en_gb_d/nkm2401.html http://www.picaxe.com/Hardware/Add-on-Modules/RF-Connect-Radio-Boards/
I think that out in the boondocks, practically any of the Tx units would work decently with practically any of the Rx units. But near The Big City, there are too many interfering RF sources for such simple receivers.
BTW, the receivers necessarily have to be broad because the SAW-based transmitter modules aren't terribly accurate. The whole system is really just a bit too cheap unless you live near Euell Gibbons.
