P2 BOOT SEQUENCE: Serial, Flash, SD, Taqoz
Cluso99
Chip,
I have been chatting with Peter J about the boot sequence and how to fit everything into the 16KB ROM and make it work nicely.
We need something a little more friendly and specific than what the boot currently does. Here are our ideas (Peter will comment on anything wrong or missing).
* No Pullup on P61 (CSn) then goto Serial
* No Pullup on P60 (CLK) then goto Flash
* (Pullup on P60 (CLK)) then goto SD
If Flash fails, revert to Serial
If SD fails, revert to Serial
FLASH:
No checksum as it's not required and makes it more difficult for tools. Instead, check for all $00's and all $FF's (ie blank) and if all $00's or all $FF's fail and revert to Serial.
Override (eg code is corrupt or buggy) can be done in parallel with Serial (downloader continually sending autobaud sequence until recognised).
SD:
No checksum. Check for "Prop" in MBR or VOL sector at offset $17C-$17F. If present, the sector contents from $080-$17F is presumed correct and loads the whole sector into COG at $000+ and then JMP $080. This makes the code simple to write to this location on the SD card.
Otherwise, the two files "_BOOT_P2.BIX" and "_BOOT_P2.BIY" are searched, and if found will be loaded into hub from $00000+ with an upper limit of HUB RAM less 16KB (ie this P2 will be (512-16)KB, and then 496 longs from Hub $00000+ will be copied to COG $000+ and then JMP $000.
If not found, or initialisation failure, then revert to Serial
SERIAL:
What we would like is for the Serial Interrupt to be enabled for both the Flash Loader and SD Loader, such that Serial is being checked in parallel to the Flash/SD loaders. This way, if the Flash/SD code contains a bug that locks the P2 in a loop somewhere, the Serial can preempt the Flash/SD loading.
The serial should wait for the autobaud characters. Once received, serial should look for the download sequence, and/or a <Ctrl-?> or <esc> (Peter to decide) to run TAQOZ. If there is ROM space, then I propose putting the monitor/debug code in there too. It will be run by a different <Ctrl-?) key (tbd).
Peter & I can work on this. I am free Wednesday & Thursday.
Chip, does this make sense to you???
FLASH:
SD:
SERIAL:
The present boot code, does not allow for reset exit variations, and it tries to infer from the status register.
I think more stable, is to loop polling for the JED ID, 0x9F, and if that timeouts ( only returning all $00's or all $FF's) then FLASH is not connected (pin is floating).
Anything not all $00.$ff in the 24b ID fields, is considered a connected flash device. Exact ID value does not matter.
A light pullup on MISO would make this more reliable - otherwise induced mains can give a false positive as it 'floats' from $0000 to $ffff.
A problem with "check for all $00's and all $FF's" on the flash content, is what value of all do you use ?
A direct binary image has unknown first byte, but it is reasonable to have a very simple [HeaderTag][LoadCount][Binaryimage...]
Now, the header tag has to match "P2v1" or whatever is chosen & a new/blank device will not.
I'm not sure
[HeaderTag][LoadCount][$ff-Checksum][Binaryimage...] is much more difficult, and should catch erased blocks type errors.
Note some systems might add a pullup to CSn, to try to ensure power up/floating pins reset, does not select the device.
That makes CSn less than ideal as a decision pivot.
ie, you do not know what baud rate is, so cannot yet set baud to enable the serial interrupt ?
Chip currently looks for ">" on a dual test of Edge/High basis, and derives Baud from that.
The expectation is nothing else will false-trigger that, so it can discard partial or wrong ASCII chars, of any baud.
Once the coarse baud is done on the first ">", there is provision for any following ">" to fine tune the baud, but they do need to be seen as ">" via the serial HW.
This is supposed to track RCFAST oscillator drift.
For fastest serial boot, the host will send continually repeating "> Prop_Chk 0 0 0 0 "
When P2 exits reset, it will autobaud trigger on the next whole ">" and then echo CR+LF+“Prop_Ver Au”+CR+LF
When it comes to loading from named SD files then I assume that the loader would be using the file size always and a signature in the boot sector.
However it is strapped for Flash or SD I believe that the serial line should always be checked for continuous synch characters so that serial can always override Flash or SD which may be buggy or simply in need of an update. Since SD needs some time to "warm up" then this check can be made while that is happening and even Flash loading and execution should be aborted but not delayed.
As for TAQOZ I will try to talk more about that on its thread but suffice to say that I can't see how this version of Forth can run from high memory since it uses a 16-bit wordcode to address most of the first 64kB of code and that still permits additional schemes for more code. So in view of this and the limited amount of ROM that we have (even P1 has 32kB) I am limiting TAQOZ to be copied into low memory from where it will run as a very useful tool in lieu of user code, not in conjunction with it. Hardware can certainly be debugged and if you had nothing else but a smartphone/tablet you could still program a P2 by pasting in plain text source code. However I would like to build a version of SPLAT into TAQOZ as a logic analyzer. Since Cluso's SD loader will be present there is no need for TAQOZ to support SD directly and also there is no room for it. If SD is present then a full version of Tachyon can be loaded that does handle FAT32 including file creation etc.
So that becomes like this ?
[HeaderTag][LoadCount][FlashAddressOffset][P2Address][$ff-Checksum][Binaryimage...]
which is commonly
[HeaderTag][LoadCountBytes][0][0][$ff-Checksum][Binaryimage...]
if FlashAddressOffset is not 0 (packed Binary image), then a new CS+Read.Address command is needed.
I think that offset case should expect the same header structure - makes sense to have blobs location independent, except for offset ?
Flash: I am referring to the data being all $00 or all $FF (ie blank). IIRC Flash reads all $FF but in case of future FLASH or equivalent that may read all $00, I think it prudent to check for both. If the preamble to the Flash fails, then it clearly should revert to Serial.
There are always restrictions and caveats. The pullups are IMHO the best and simplest way. There are no internal fuses to check.
Pullups are fine, the point was to not use CSn as one, as commonly designs already pull that up, for safety reasons.
If Flash used
P61 = CSn (with pullup)
P60 = CLK (no pullup)
and the SD used
P61 = CLK (no pullup)
P60 = CSn (with pullup which can be internal to the card)
we would only require 1 pullup for either Flash or SD.
Now, by having a pullup on both P61 & P60, both Flash & SD could most likely co-exist. The boot should then assume Flash to be the priority and boot from it.
TAQOZ is a special language so the user will need to understand TAQOZ. It looks like it will not be able to be called from the user program.
You can see that if SD boot fails, we don't attempt serial, because an indeterminant amount of time as has passed by. By doing what JMG proposes, where we just keep sending the connect string until we get a response, we could recover to serial after an SD boot failure.
We need to figure out how/when to turn things over to TAQOZ. TAQOZ can relocate itself to lower memory, no problem.
What do you guys think?
But they only pull-up P61 CSn if they've got some memory connected, in which case we pursue booting from it.
No pull up on P61 means NO memory is connected, so don't twiddle any more I/O's. Just wait for serial.
Here's a sample disas output. I hope to finish the docs for this in the next few days and post the code.
The debugger is rich in features and uses the hardware single-step and break features of the P2.
Support for bytecode engine debug is also included.
So, the monitor provides user callable routines which run in hubexec ROM. They require 16 cog longs at $1E0-$1EF for parameter passing and workarea for the hubexec routines.
Please tell me if you are not interested, as I will need to finish the input routine tomorrow. All else is working and has been tested. Here is a link to more info...
I don't know how much space Peter will require for TAQOZ, and if my monitor will fit with TAQOZ. Peter and I intend to chat tomorrow.
I had a disassembler in my monitor for P2 prior to P2Hot.
Ozprop now has a disassembler for V32, so there is no point in redoing it. His also works with single-step and break.
I don't see why we cannot revert to serial if SD fails.
The same applies to Flash. If it fails, then revert to serial.
Why can't we... The P2 has multiple cogs, so why not use them
The code to check for autoboard can set the serial-found-flag. If Flash or SD is attempting to boot, it does not need to respond to the serial until the flag is cleared by the Flash/SD code.
So Flash & SD boot code just needs to check the flag before continuing to execute. This overcomes the problem where Flash or SD could overwrite serial code downloaded. Serial would overwrite any code read by flash/sd.
This allows for the situation where the Flash (or for that matter SD) code is corrupt/buggy and we want to override the flash/sd code with new downloaded code. No need for a pullup or no-pullup, so we don't have to modify a pcb to override the flash code!!!
Peter & I will try to work thru this tomorrow. Are you available Chip?
Yes, I am available. Just pm me.
Don't forget the time to exit reset varies, so the code needs to include the reset-from-Quad, and flash-is-awake test (SD may need similar)
I would also be quite wary of any code like this That gives a simple attack vector, and also means any watchdog reset while a host is streaming serial data, can disturb a reboot.
And if TAQOZ can not coexist with other running software, it might be better to include @ozpropdev's debugger instead.
Else the P2 will go down as the FORTH processor and then we also can include the beany-propeller-hat.
For someone wanting to have nimble (no hands) Serial/Flash/Serial/Flash mixed testing & development, perhaps a simple serial command that forces boot from flash can do ?
This simply jumps from serial parser, into the reset header of flash loader code.
I think "~" is `run from memory`, so another key char could be `load from flash and run` ( or 'Prop_fla 0 0 0 0 FlashStart FlashCount', if you tacked on to existing Prop_xxx keystrings ?
Addit:: and 'Prop_bsd 0 0 0 0 SDindex SDCount', for boot from SD ?
Very useful here could be a Code Start address and Byte count. Then a PC/host can use the boot command to select from a whole range of known firmware, saving flash wear.
Well, yes... but I can see a use case where someone uses both a Serial small MCU for secure stage 1 loading, and a Flash memory.
In this case, the CSn pullup is there, but you want serial first.
ie can another pin like CLK or MOSI be used for the pullup, rather than CSn ?
Personally, I prefer to avoid a Serial within flash gateway, as that has watchdog issues and attack issues.
Hence the suggestion to also allow a command for `Serial mode to jump to flash boot` - useful for simple host firmware selection, and factory testing.
Good question. Some ROMs are designed as top-layer only changes, not sure about this OnSemi ROM ?
It is also quite rare for chip vendors to release revision A parts to full production.
A related question is with the lowered logic usage, from refined timing, is there room to bump the ROM to more than 16k (32k? 48k? 64k?)
