DVI Works! - Page 2 — Parallax Forums
DVI Works!
2»
  • RaymanRayman Posts: 13,897
    edited 2009-11-10 14:37
    I'm not having any luck at all getting XGA to work, even with some mosfets to invert sync polarity...
    Think I'll punt for now and try again later using the I2C bus to control things transparently...
    Maybe I can use the chip's internal DE generator that way and save a pin too...
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
  • MarkSMarkS Posts: 342
    edited 2009-11-13 05:58
    Rayman, where did you get this part? Jameco doesn't know what it is, and both Digi-key and Mouser are out of stock, with Mouser giving a 2/15/2010 stock date. This is exactly what I need for a project.
    edited 2009-11-13 14:10
    I think I got mine via free sample, but I'm pretty sure I saw them at Digikey too...
    edited 2009-11-13 15:36
    Digikey *carries* them. They are out of stock with a 20 week lead time.
    I was looking at the free samples, but they ask for a company name. I'm not sure if that is required or not.
    [noparse][[/noparse]edit]
    So, I'm applying for the free sample and it is asking me to "select your end equipment"? What the heck is "end equipment"?! confused.gif To make matters worse, I have to type something. I don't have the slightest idea what to type.
    Post Edited (MarkS) : 11/13/2009 4:00:50 PM GMT
    edited 2009-11-14 02:36
    That is strange... I swear they were in stock a month or so ago...
    Digikey seems to have a bug because they show 263 in stock until you try to get one...
    TI direct is out of stock, 20 weeks, but they say these guys have a lot, but don't give a price:
    http://www.rocelec.com/about/searchresults/TFP410PAP/
    edited 2009-11-14 05:47
    I finally figured out the sample thing. They stated the sample will be sent out after 12/5. That's still better than 2/15! Must be really popular chips.
    edited 2009-11-14 06:32
    Funny because I think it's a relatively old chip...
    The I2C accelerometer I just started looking at is also on the endangered chip species list, but that is more understandable...
    It's very strange, almost like running out of Prop chips [noparse]:)[/noparse]
  • BradCBradC Posts: 2,601
    edited 2009-11-14 09:21
    MarkS said...
    The trick here is to be honest. I have a company name so I use that, and I get as close to the "end equipment" as I can in description. Prior to that I just said I was a student and using it for a university project. You pretty much can't get it exact anyway. I always state the lowest production qty (<1000 per annum) and I've yet to be knocked back.
    If you always do what you always did, you always get what you always got.
    edited 2009-11-15 17:32
    BradC said...
    MarkS said...
    Yes, I was honest. I put "N/A" under business and "hobbyist" under my position at this non-applicable company. There should be no doubt who they're sending a sample to.
    edited 2009-11-15 17:49
    Well, you don't have to be TOO honest... Actually, I think I may have made up my company name just so I could put something down for free samples [noparse]:)[/noparse]
    edited 2009-11-16 03:14
    Some companies are anal enough to actually check the validity of the company listed. I figured that honesty would be best here. At worst, they deny the request. If they keep records and and their records showed that I lied about the company and was denied, I may have problems later on if I have a real company name.
    So far, so good though.
    Somebody asked me about this ancient project so I'm posting the design file here in case anybody wants to look at it.
    It's ExpressPCB.
    I think I fixed the wiring issue that the first version had, but can't remember for sure...
