push button — Parallax Forums
push button
i want to controlling LED by using two push buttons switch, like two switch in electrical
  • Have you seen these tutorial pages?
    https://learn.parallax.com/tutorials/language/pbasic/whats-microcontroller
    There is a free PDF book you can download which seems to cover your question.
    https://www.parallax.com/downloads/whats-microcontroller-text
  • $WMc%$WMc% Posts: 1,884
    edited 2018-02-25 06:00
    ' BUTTON.BS2
    ' Connect an active-low circuit to pin P0 of the BS2. When you press the
    ' button, the DEBUG screen will display an asterisk (*). The program, as
    ' shown below, will print an asterisk at the first button press, then
    ' delay approximately one second (200 x 5 ms PAUSE) before auto-repeating
    ' at a rate of approximately 100 ms (5 x 20 ms). Feel free to modify the
    ' program to see the effects of your changes on the way BUTTON responds.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    Btn PIN 0
    btnWrk VAR Byte
    Main:
    ' Try changing the Delay value (255) in BUTTON to see the effect of
    ' its modes: 0 = no delay; 1-254 = varying delays before auto-repeat;
    ' 255 = no auto-repeat (only one action per button press)
    ' The BUTTON instruction will cause the program to branch to
    ' No_Press unless P0 = 0
    PAUSE 5
    BUTTON Btn, 0, 200, 20, btnWrk, 0, No_Press
    DEBUG "*"
    No_Press:
    GOTO Main
    Take a look at the above...This demo just shows how to do it, You real code will only be one or two short lines.$WMc% out
