Questions about the P2 instrution set for anyone but Chip - Page 4 — Parallax Forums
124»
  • rjo__rjo__ Posts: 2,114
    I wanted to focus on the offending code.
    Here is the complete code... I think it is failing hardware, but I have thought that before.
    The story is I spent a couple of days soldering a couple of LaserPings to a slip ring and mounting the thing to a Parallax feedback 360 servo... assuming that the code would be a no brainer... first I couldn't get the smart pins to cooperate.. then I couldn't get the edge detectors to cooperate... and now I am reduced to this:) The idea is that when you make momentary contact with 3.3v... the moment is spit out to serial, with the first clock and the total period reported AND the LED lights up during contact... this actually does work!!! But seeing that LED stay dimly lit has me befuzzled.
    The code snippet starts around line 74
    ok... I see it... thanks.
    looked at it for two ....ing days... Lordy
    Questions...
    I presume that this is invalid
        _ret_   call     #label
    Thinking some more...
    It would just require the verilog to NOT push the new return address onto the stack. I wonder if Chip thought about this?
  • how about doing a JMP instead of _RET_ CALL.....?
    there is probably a ret at the end of the code of label?
  • cgraceycgracey Posts: 14,319
    Cluso99 wrote: »
    Questions...
        _ret_   call     #label
    The _RET_ only executes if not preempted by a branch. This means that '_RET_ DJNZ X,#loop' will only RETurn when the looping is done. In your example, the CALL would always take precedence over the _RET_.
    edited 2018-05-11 06:06
    Now here's another one. I've been setting the carry with "modc 1 wc" but I'm told it should be "modc %1111 wc" however this test with MODZ says only the lsb is used.
    First, the test word in TAQOZ which is simply called MODZ at the high level.
    ' MODZ ( n -- set )
    _MODZ			altd	tos,#0
    			modz	0 wz
    			mov	tos,#0
    		if_z	mov	tos,#1
    			ret
    So it will return a 1 if the z is set.
    Now the test....
    TAQOZ# 0 16 ADO CRLF I .B SPACE I MODZ . LOOP
    $00 0
    $01 1
    $02 0
    $03 1
    $04 0
    $05 1
    $06 0
    $07 1
    $08 0
    $09 1
    $0A 0
    $0B 1
    $0C 0
    $0D 1
    $0E 0
    $0F 1 ok
    Only the lsb was recognized.
    ' MODZ ( n -- set )
    _MODZ			altd	tos,#0
    			modz	0 wz
    			mov	tos,#0
    		if_z	mov	tos,#1
    			ret
    Now the test....
    $00 0
    $01 1
    $02 0
    $03 1
    $04 0
    $05 1
    $06 0
    $07 1
    $08 0
    $09 1
    $0A 0
    $0B 1
    $0C 0
    $0D 1
    $0E 0
    $0F 1 ok
    Using %0001 means z = !c & !z.
  • Ahhh, so it does...
    TAQOZ# 1 MODZ . 0 ok
    TAQOZ# 1 MODZ 1 MODZ . 1 ok
    TAQOZ# 1 MODZ 1 MODZ 1 MODZ . 0 ok
    But that's kinda scary that we are using all these instructions that haven't been documented yet!
  • From "instructions_v32.txt"
    MODCZ constants
    _CLR                    =       %0000
    _NC_AND_NZ              =       %0001
    _NZ_AND_NC              =       %0001
    _GT                     =       %0001
    _NC_AND_Z               =       %0010
    _Z_AND_NC               =       %0010
    _NC                     =       %0011
    _GE                     =       %0011
    _C_AND_NZ               =       %0100
    _NZ_AND_C               =       %0100
    _NZ                     =       %0101
    _NE                     =       %0101
    _C_NE_Z                 =       %0110
    _Z_NE_C                 =       %0110
    _NC_OR_NZ               =       %0111
    _NZ_OR_NC               =       %0111
    _C_AND_Z                =       %1000
    _Z_AND_C                =       %1000
    _C_EQ_Z                 =       %1001
    _Z_EQ_C                 =       %1001
    _Z                      =       %1010
    _E                      =       %1010
    _NC_OR_Z                =       %1011
    _Z_OR_NC                =       %1011
    _C                      =       %1100
    _LT                     =       %1100
    _C_OR_NZ                =       %1101
    _NZ_OR_C                =       %1101
    _C_OR_Z                 =       %1110
    _Z_OR_C                 =       %1110
    _LE                     =       %1110
    _SET                    =       %1111
  • So I also need instructions on where to look for instructions too! Thanks.
    So modz %1100 wz copies C into Z. But what if we don't use wz?
  • So modz %1100 wz copies C into Z. But what if we don't use wz?
    Z state wold remain unchanged.
  • Yes, but would there ever be a reason to not specify wz or is it simply mandatory?
    Cluso99 wrote: »
    Questions...
        _ret_   call     #label
    Thanks Chip. Actually if we had though about it earlier, it could have been simple to make it work. Just don't push the call's return address onto the stack. This way, the call's return would bypass this call's return address, and go directly to the previous return address. Saves 2 clocks to boot ;)
    edited 2018-05-11 09:58
    Instruction MODCZ/Z/C
    What do you think this instruction does?
                    modz    1                       wz      ' =0001
    Nope! It inverts Z! So in the test below you will see NZNZNZNZNZ... ;)
    Here are the tests...
    		mov	lmm_x, #0       wz	' preset "Z"
    loop
    '		modz    1111	      wz	' set "Z"
    '		modz    0000          wz      ' set "NZ"
                    modz    1             wz      ' invert "Z" (0001)
    	if_z	mov	lmm_x, #"Z"
    	if_nz	mov	lmm_x, #"N"
    		CALL	#@_HubTx
    		jmp	#loop
    Postedit:
    I have just seen the above discussion with ccodes.
    Not sure about anything other than 0000 and 1111 anymore. No time now tho'.
  • modz 1 wz
    is the equivalent of
    modz _nc_and_nz wz
  • Confirmation of "modz 1 wz" operation.
    	modcz	_clr,_clr wcz	'clear c , clear z
    	modz	1 wz	'z = !c & !z, z = 1
    	modcz	_set,_clr wcz	'set c, clear z
    	modz	1 wz	'z = !c & !z, z = 0
    	nop
    Returns the following flag states
    >(P2 Debugger V3.34_V32c)================================================================================================
    00000: FD7C006F              MODCZ   _CLR,_CLR WCZ
    Flags (CZ) = __
    00001: FD6C026F              MODCZ   _CLR,_NC_AND_NZ WZ
    Flags (CZ) = __
    00002: FD7DE06F              MODCZ   _SET,_CLR WCZ
    Flags (CZ) = _Z
    00003: FD6C026F              MODCZ   _CLR,_NC_AND_NZ WZ
    Flags (CZ) = C_
    00004: 00000000              NOP
    Flags (CZ) = C_
