Why does my 556 Suck?
Question for the analog gurus (Tracy, Beau, Gordon et al): My old school 556 timer is sucking current at a prodigious rate. Building a battery powered NE556 IR signal generator, and I'm shocked to learn that the 556 is pulling 25 mA not even driving the IR LED! That will kill my 9V battery right quick. Both timers are oscillating but there's no load. Then I tested a bare 556 chip with no circuitry, just battery connections, and it's still pulling 16 mA not doing anything! Yes, I tested several.
Tested a 555 timer, that only drew 2.7 mA alone so I rebuilt my 556 circuit using two 555's and it's right back up to 28 mA with no IR LED. Can't win! Now I understand why the low-power CMOS 7555 timer is such a big deal.
This makes the case for going digital, but honestly I'm shocked what power hogs these are. 25+ mA idle current is ridiculous, that's about what I need to send through the IR LED.
Where is all that current going?
Have you determined the chip isn't oscillating when open circuit?You might connect up parts for a really long output and see what you get, and use that as a known baseline.
As for being power hogs, it's long been suggested to put 1uF caps across the power pins for these. They can put out a lot of trash into the power rails.
2 pcs 555 timer = 28 mA
Makes no sense!
One 555 draws 2.7 mA by itself, only power connections. Two 555s wired together with all timing caps & resistors but no output LED draws 28 mA. Still seems hinky.
@Gordon: Not TI, you know I use only cheap authentic Chinese Ebay chips
Will try the filter caps you suggest.
Now I'm really glad I ordered more of these 9V Lipos: https://www.banggood.com/OKcell-9V-800mAh-USB-Rechargeable-Lipo-Battery-for-RC-Toy-p-1022214.html
Do an experiment: Connect two 555s together (astable) so that the first one has a 10 second or longer delay, triggering a second 555 with a delay of at least as much. IOW, you want a steady logic level for at least 10 seconds for both stages so you can get a reading. What kind of current load does that create? Seems to me it should be much closer to the ratings in the spec than what you're getting.
Assuming you're aiming for production quantities, pricewise could you substitute with a really cheap OTP processor, maybe one with a built-in resonator? For a demonstration prototype the higher draw/shorter battery life shouldn't be too terrible -- all you need is the batteries to last long enough for them to approve the design and cut your check!
Spoken like the mad genius you are. I'm making ten units for NYTF, will have to live with the non-optimized battery life for now. I have all these cheap Chinese chips and I'm gonna use 'em!
