Solved - PING alternative HC-SR04 coding problem! — Parallax Forums
Jorge PJorge P Posts: 385
edited 2018-01-20 13:20 in Propeller 1
Hi all, it's been quite a while since I used the propeller and I've run into a coding problem while trying to get the HC-SR04 working. Here is my code so far, some of it borrowed from other locations.
I have it running but either my timing is wrong or my distance calculations are wrong.
HC-SR04 Product Page
HC-SR04 datasheet
I am getting unexpected measurement results and modified the code somewhat while trying to figure it out.
Thanks in advance.
  Sparkfun's HC-SR04 Ultrasonic Sensor on the Propeller :)
  I've only seen this in C code for the Propeller so here it is
  in SPIN.
CON
        _clkmode = xtal1 + pll16x
        _xinfreq = 5_000_000
        TRIG   = 1  ' Connected to P1
        ECHO   = 0  ' Connected to P0
        HIGH   = 1
        LOW    = 0
        INPUT  = 0
        OUTPUT = 1
        MAX_DIST = 23_200
        DEBUG = 1            ' 1 = true, 0 = false
        ' from Timing.spin
        _10us = 1_000_000 /        10                         ' Divisor for 10 us
        _1ms  = 1_000_000 /     1_000                         ' Divisor for 1 ms
        _1s   = 1_000_000 / 1_000_000                         ' Divisor for 1 s
        ' from dualPing.spin
        TO_IN_std = 74_641  ' std atmosphere speed of sound, us per inch traveled @ 59F air temperature
        TO_CM_std = 29_386  ' std atmosphere speed of sound, us per cm traveled @ 59F air temperature
OBJ
        pst : "Parallax Serial Terminal"
VAR
        LONG pulse_Start
        LONG pulse_Stop
        ' from Timing.spin
        LONG delay
        LONG syncpoint
        LONG clkcycles
PUB Main | Microseconds, Distance, cnt1, cnt2
    waitcnt(clkfreq * 5 + cnt)
    pst.start(115200)
    ' set pin directions
    OUTA[TRIG] := HIGH        ' Direction not set but set the state low
    DIRA[TRIG] := OUTPUT      ' Set to Output
    OUTA[TRIG] := LOW         ' Ensure it is still Low
    DIRA[ECHO] := INPUT       ' Set the echo input
    IF DEBUG == 1
      pst.Str(STRING("Directions Set, ready for testing!"))
      NL
    REPEAT
      ' main loop
      OUTA[TRIG] := HIGH
      pause10us(1)
      OUTA[TRIG] := LOW
      WAITPNE(0, |< ECHO, 0)
      cnt1 := CNT
      WAITPEQ(0, |< ECHO, 0)
      cnt2 := CNT
      Microseconds := (||(cnt1 - cnt2) / (CLKFREQ / 1_000_000)) >> 1
      if DEBUG == 1
        pst.Home
        pst.ClearEnd
        pst.Dec(Microseconds)
        pst.Str(STRING(" us. "))
      Distance := Microseconds / 58
      IF DEBUG == 1
        pst.Dec(Distance)
        pst.Str(STRING(" cm."))
      pause1ms(100)
PUB Inches(ms) : Distance
''Measure object distance in inches
  Distance := ms * 1_000 / TO_IN                                        ' Distance In Inches
PUB Centimeters(ms) : Distance
''Measure object distance in centimeters
  Distance := Millimeters(ms) / 10                                             ' Distance In Centimeters
PUB Millimeters(ms) : Distance
''Measure object distance in millimeters
  Distance := ms * 10_000 / TO_CM                                       ' Distance In Millimeters
'from dualPing.spin
PUB calibrate(Tamb)
    ''Adjust Ping))) calibration constants to reflect ambient
    ''temperature impact on speed of sound (temperature assumed to be °F)
    Tamb += 460
    TO_IN := TO_IN_std * (^^(Tamb * 1_000_000)) / (^^518_690_000)
    TO_CM := TO_IN * TO_CM_std / TO_IN_std
'From Timing.spin
PUB pause10us(period)
    '' Pause execution for period (in units of 10 us)
    clkcycles := ((CLKFREQ / _10us * period) - 4296) #> 381    ' Calculate 10 us time unit
    WAITCNT(clkcycles + CNT)                                   ' Wait for designated time
'From Timing.spin
PUB pause1ms(period)
    '' Pause execution for period (in units of 1 ms).
    clkcycles := ((CLKFREQ / _1ms * period) - 4296) #> 381     ' Calculate 1 ms time unit
'From Timing.spin
PUB pause1s(period)
    '' Pause execution for period (in units of 1 sec).
    clkcycles := ((CLKFREQ / _1s * period) - 4296) #> 381      ' Calculate 1 s time unit
'From Timing.spin
PUB marksync10us(period)
    delay := (CLKFREQ / _10us * period) #> 381                 ' Calculate 10 us time unit
    syncpoint := CNT
'From Timing.spin
PUB waitsync
    WAITCNT(syncpoint += delay)
PRI NL
    pst.NewLine
PRI CLS
    pst.Clear
DAT
'-----------[ Predefined variables and constants ]-----------------------------
        TO_IN         LONG      74_641                  '
        TO_CM         LONG      29_386
  • Is the logic protocol the same as Ping?
    Ping idles low and asserts high.
  • VonSzarvas wrote: »
    Is the logic protocol the same as Ping? Ping idles low and asserts high.
    Yes, according to its datasheet it is.
    And just to clarify, I am getting results but I can only detect readings between 2 and 6 centimeters. it should be more between 2 and 400 according to the specifications so I think some timing calculations, I have are off, which should be more apparent to someone with more experienced with spin than I am.
  • Oops was a bad hole on the breadboard, code works fine :/ I checked all 10 units and they work with this code! I used a ruler to test the distance measurement and it seems to be calculated from the HC-SR04 units PCB and not from the Ultrasonic sensors. Got readings out to 1,000mm then I couldn't read the screen of pst.
      in SPIN.
    CON
            HIGH   = 1
            LOW    = 0
            INPUT  = 0
            OUTPUT = 1
            MAX_DIST = 23_200
            ' from Timing.spin
    OBJ
    VAR
            LONG pulse_Start
            LONG pulse_Stop
            ' from Timing.spin
            LONG delay
            LONG syncpoint
            LONG clkcycles
        pst.start(115200)
        IF DEBUG == 1
          NL
        REPEAT
          ' main loop
          OUTA[TRIG] := HIGH
          pause10us(1)
          OUTA[TRIG] := LOW
          cnt1 := CNT
          cnt2 := CNT
          if DEBUG == 1
            pst.Home
            pst.ClearEnd
          Distance := Millimeters(Microseconds)
          IF DEBUG == 1
            pst.Dec(Distance)
            pst.Str(STRING(" mm."))
          pause1ms(100)
    'from dualPing.spin
    PUB calibrate(Tamb)
        Tamb += 460
    'From Timing.spin
    'From Timing.spin
    'From Timing.spin
    PUB pause1s(period)
    'From Timing.spin
        syncpoint := CNT
    'From Timing.spin
    PUB waitsync
    PRI NL
        pst.NewLine
    PRI CLS
        pst.Clear
    DAT
            TO_IN         LONG      74_641                  '
            TO_CM         LONG      29_386
