Collecting Servo Specs
GordonMcComb
in Robotics
I'm collecting some basic factoids about popular continuous rotation servos. I don't have all models to test, so I'm wondering if anyone has a Spring SM-S4303R (Pololu 1248, among others), would you know off-hand what direction the servo turns with 2ms pulses? There are a few servos that go the other way, and I'm filling out a chart. The direction should be noted as CW or CCW, when viewed with the shaft straight on.
Thanks in advance!
Thanks in advance!
The 4306 moves clockwise for 2 ms pulses.
Do you happen to have a (non-feedback) Parallax servo handy? Does it also go CCW? All I can find right now is the Feedback version, which is CCW for 2ms pulses. I am assuming both are CCW, because they now use the Feedback 360 with the Activity Bot, though I imagine they could have gone through all the code and flipped the directions.
Or I might be lying outright.
The Parallax CR servos on my old BoeBot turn CCW on 2 ms pulses.
