Collecting Servo Specs — Parallax Forums
I'm collecting some basic factoids about popular continuous rotation servos. I don't have all models to test, so I'm wondering if anyone has a Spring SM-S4303R (Pololu 1248, among others), would you know off-hand what direction the servo turns with 2ms pulses? There are a few servos that go the other way, and I'm filling out a chart. The direction should be noted as CW or CCW, when viewed with the shaft straight on.
Thanks in advance!
  • ercoerco Posts: 20,254
    Pretty sure I have some, will check tomorrow.
  • Thanks! Looking forward to your report, kind sir!!
    Oops, turns out I have the Spring SM-4306R, not the 4303.
    The 4306 moves clockwise for 2 ms pulses.
  • Erco, Thanks. Other sources specifically indicate CCW for the 4303. The 4306 might be an outlier.
    Do you happen to have a (non-feedback) Parallax servo handy? Does it also go CCW? All I can find right now is the Feedback version, which is CCW for 2ms pulses. I am assuming both are CCW, because they now use the Feedback 360 with the Activity Bot, though I imagine they could have gone through all the code and flipped the directions.
    Or I might be lying outright. :)
    The Parallax CR servos on my old BoeBot turn CCW on 2 ms pulses.
    For some reason this time when I looked at the title "Servo Specs", I had a vision of some motorized multi-lens Inspector Gadget eyewear... is it just me?
    380 x 380 - 15K
    Getting old! I forgot I had videoed my 4306 servos over a year ago.
