Basic Stamp 2 with RS232
Hello, I need to use the BS2 IC module, I need to know if this scheme is OK, to connect to a computer through the rs232 port.
Thanks.
  • (Welcome to the forum!) And it should work. However the Stamps do prefer boards that Parallax make. And as it happens that's the basic layout for the boards that Parallax provides for the Stamp2. Such as the regular carrier board and one much larger.
    Strange.... There's a cat and an erco robot in the room with you.
