SimpleIDE - Need bot connected to compile? — Parallax Forums
Does anyone know if there is a way to compile code on the SimpleIDE without having my Activity Bot attached?
I would love to write code without having the bot with me at all times. I see there is a way to test in the terminal but I have not been able to figure out yet if I can do so without connecting my bot.
Thank you!
-Colt
  • If you just want to compile the code you can do so by clicking on the hammer icon. If you want to run the code without hardware you need a simulator, such as Gear or spinsim. However, the simulators won't help in testing servos or anything else connected to the pins.
  • Ah, I see. I can test the math/logic later. I simply want to be able to continue to code when the bot is not directly next to me.
    I appreciate the help!
    -Colt
