$7 Android/PC Endoscope Waterproof Camera
Erco's daily find, a tiny camera on a long cable to look into Corvair spark plug holes. Illuminated! Waterproof! I ordered the 2-in-1, 5.5mm, 2M one for $6.64. It's worth that just for the nifty convertible USB/micro tip. Never seen that before.
Duane, you need 3.
http://www.ebay.com/itm/152404167846
Duane, you need 3.
1.3 megapixels, so I'm not expecting much in the way of image quality.
I might have to get one of these too. Even a crappy image is valuable at that cost.
I was waiting for some kinda Obamacare colonoscopy joke, but you took the high ground!
If the resolution is half of optimal, is it a semi-colonoscopy?
It does say the resolution is 640*480, with 1280*720 for PCs only; the latter spec suggests they're doing pixel doubling in software. It's the output image, not the image pixels (which counts unused periphery pixels), you have to go on to determine image resolution.
Another seller of the same camera lists the operating temperature is up to 120 degrees C (not F, but C). Yeah, right.
Hey, I'm only quoting the seller, who is bound by honor, duty and eBay rules to maintain accurate item titles & descriptions. But yeah, you're the forum stickler for terminology, Mr. "Don't You Call it Differential Drive. "
I have one of these somewhere. If I find it I'll pick an orifice at random and post a video.
Please, nothing below the eyebrows.
Or at least below the chin.
I hope the forum don't become an online ENT clinic.
Ah, what might have been!
I've never seen a USB connector like that, pretty neat!
I was planning to crack a smile in my video!
I think Erco's planned use as an inspector for the spark plug holes in his Corvair is the best I've heard. He'll discover there are actually no pistons or valves in there. It's all a family of squirrels.
With a bore light on the opposite end, and moving the camera around you can see defects in the rifling, copper fouling, and other deposits. I normally just look at the screen while doing this and don't make a video. From the shot of the bore above you can see some lint (dust) and some of the factory goop they use in shipping. This is a new rifle I'm working with so it has not seen it's first clean (scrubbing) yet.
The still feature I don't use much. But might start using it to document throat erosion over the life of this barrel.
Just my guess, but using the live video feature works the best, same resolution but it seems like you can 'see' more detail from a series of pictures (video).
LED's run warm, not enough to burn you. You can adjust the brightness with the button at the other end of the cable, but there's only 3 settings (really bright, dim, and dimmer) along with off.
Seems to be able to focus up to 1 or so inches from the subject.
The microUSB (or whatever it's called, I gave up trying to track the variations) connector is a bit tight. The dual connector is neat, though when connected to my phone the phone can't lie flat because of the hinged part of the connector.
I didn't use the software that was recommended for download... so I can't comment on it. I used CameraFi (Android) and YAWCAM (PC) and they both seemed to work fine with it.
Still, it works well. Thanks for pointing out another toy useful tool, erco.
Not too impressed with picture quality but didn't expect much for $7...
RAAAAAAANNHHR!
