Smart Pins Docs and features
1235713
  • cgraceycgracey Posts: 11,273
    edited 2017-06-09 - 18:23:50
    For a few extra gates, I just added some functionality to the mode %10010.
    Y[1:0] now selects what gets tallied:
    %11 = a-edges
    %01 = a-rises
    %x0 = a-highs
    This gives it a little more flexibility.
    edited 2017-06-09 - 18:31:45
    There was some concern about the gated-counter mode.
    What we have just accumulates A-rises when B is high, reporting periodically or continuously.
    I think what is wanted is a mode where Z is incremented each time A rises when B is high. When B falls, the Z is reported. A new count begins in Z when B goes high. Is that right?
  • jmgjmg Posts: 13,618
    edited 2017-06-09 - 20:38:09
    Mode %10000 is used by the boot ROM for automatic baud detection. It works great there.
    Yes, interval timing is widely useful.
    %11 = a-edges
    %01 = a-rises
    %x0 = a-highs
    That sounds more useful, I prefer more user control over fixed, canned choices.
    So mode %10010 is now : Window-By-A
    Where Am is one of Ah,Ae,Ar
    Repeat until Sum(Am) >=N; Report dT
    - dT is the time for last instance of Sum(Am) >=N;
    The edge versions give Time for N cycles
    Sounds like this needs a paired version that does Window-By-Time
    Repeat Sum(Am) until dT >=N; Report Sum
    The edge versions give Cycles per Nt.
    Seems those could merge with other modes ?
    Yes, that is a classic Gated Counter with Capture, for N=1 case.
    For N>1, it reports Z, after N falls on B.
    Because B is the clock enable, effectively yes, 'A new count begins in Z when B goes high', however if B is high when the state starts, that should be valid.
    In some cases, the Gate is a trailing edge only.
    In all modes, I think a flag should signal if a second capture occurred before the user read the signal.
    That tells them they either need to change ranges, or discard/reality check that reading.
    Leading and trailing edge glitches will be common, you do not want them invisible.
  • Don't remove the totalizer feature from mode %01100.
    "... peers into the actual workings of a quantum jump for the first time. The results
    reveal a surprising finding that contradicts Danish physicist Niels Bohr's established view
    —the jumps are neither abrupt nor as random as previously thought."
    edited 2017-06-09 - 23:34:46
    evanh wrote: »
    I think that is the x sets N=0 case ?
    The mode
    %01100 = Count A-input positive edges when B-input is high
    X[31:0] establishes a measurement period in clock cycles.
    If zero is used for the period, the measurement operation will not be periodic, but continuous, like a totalizer, and the current 32-bit high count can always be read via RDPIN/RQPIN.
    so that's not quite a simple Gated Counter, but one that is Time-gated as well.
    An artifact of this, is if dT happens to hit a Bh state, you get a partial gate effect, but if dT happens to hit !Bh, you get full-gate counts, (but do not know how many Bh are included)
    This comes back to the general premise that xNT should have a user choice of SysCLKs or Pin-events as a Clock.
    This operation is what the DOCs say now :
    If set as xNT.clk = SysCLK, mode %01100 runs for a X-set dT, and reports whatever 'B Enables A' has counted to in that time, including partial gates. Pin cell captures every dT
    If set xNT.clk = Bevent, now X sets the number of B falls before the capture occurs. Pin Cell captures after Sum(Bf) >=X
    This is the change Chip mentions above, I think.
    In both cases, I think X=0 sets the same, continually readable ('continuous, like a totalizer,') operation. Any xNT effects are disabled.
    One question on this code example....
    .wt		testp	#0	wc	'wait for initial measurement
    	if_nc	jmp	#.wt
    Is there no single opcode, 1 clock granular exiting, Wait for Pin Capture opcode ?
    Seems the 2 lines opcode polling will be 4 sysclk granular ?
  • Reading the docs, there is two: Wait on selected event (WAITSEx) for a specific pin edge, or wait on a pin pattern (WAITPAT).
    edited 2017-06-11 - 16:44:26
    I could have done it using a wait-event, but I didn't know the format at that moment, so I just typed a two instruction loop.
    edited 2017-06-13 - 07:39:28
    Today, I improved the noise filtering on the smart pins. Before, we had four different modes that were fixed and assumed a 160MHz clock rate.
    Now, we have have four system-level settable filter modes that pick clock-over-1/2/4/8/...2G as the sample rate and 2/3/5/8 bits of sample pipeline that must be all high or low to change the filter output.
    The four different filter settings are established by SETCLK:
    SETCLK ##%01nn0000_00000000_00000000_0pprrrrr
    %nn = filter setting to establish (0..3)
    %pp = sample pipeline depth of 2/3/5/8 bits (0..3)
    %rrrrr = sample rate of system clock divided by 1, 2, 4, 8, ...2G (0..31)
    Patterns %100..%111 in the %FFF bits in the WRPIN data select filter settings 0..3 for each smart pin.
    The four modes are initialized on reset as follows:
    mode 0 = %00_00000 = depth of 2 at clock/1 = 12.5ns @160MHz
    mode 1 = %01_00101 = depth of 3 at clock/32 = 600ns @160MHz
    mode 2 = %10_10011 = depth of 5 at clock/512K = 16ms @160MHz
    mode 3 = %11_10110 = depth of 8 at clock/4096K = 210ms @160MHz
    I think this should cover filtering pretty well. This added a negligible amount of logic to the hub and then 1 flop per smart pin. I felt, as did others, that the previous implementation was rather lacking.
    Sounds useful.
    What is the fastest External Clock toggle frequency in Counter modes ?
    Is that < SysCLK/2 (one sample high, one sample low), or something slower ?
    Phew, I was worried that granularity was gone, in the latest Pin-opcode round...
    I have a design case here, typical of software assisted links, where it needs to
    - Wait for an Edge on a Pin, or wait for N-edges on a Pin
    - Output , or read, data to data pins
    Very similar to software based SPI.
    With these latest filtering choices, and opcode delays, what is the SysCLK delays in P2, for Pin-Edge-Wait to Data-Change or Data-Sample ?
  • cgracey wrote: »
    Now, we have have four system-level settable filter modes ...
    Selection of four at each pin, Luxurious!
  • Out of curiosity, has anyone played with the smart pins for controlling things like servos, steppers, and motor controllers? Or implemented PID control? With the consensus that the P2 will be well suited for machine control, is stands to reason that the smart pins should be easy to use for this purpose. With the recent discussions about needed pin modes, I figured it would be a good idea to make sure we have excellent coverage for these use cases (as long as it doesn't delay the chip).
  • DAC and PWM outputs are excellent. Stepper pulses will be a little more involved around the pulse rate modes. I note there is comments about specifying a number of pulses, so it should be possible to control positional distances as well as speed.
    I've always worked at the DAC level and using positional feedback so haven't thought about steppers much historically.
  • Seairth,
    I've just poked modes %00100 "pulse/cycle output" and %00101 "transition output". Both are pulse streaming output modes.
    Neither of them are buffered, so not particularly great for stepper use.
    %00101 counts out transitions and is not too bad at chaining successive segments. To prevent any glitch in the pulse timing, when directly waiting, it requires a minimum of 12 clocks setting for the transition period. Longer periods would be required when chaining segments via interrupts.
    %00100 appears to be flawed, it has a built-in trailing bias that prohibits seamless chaining of segments. See attached snap, I've intentionally used lower frequency to highlight that the bias is based on the length of the pulse period.
    1090 x 480 - 7K
  • Here's the source code. Mode is set to %00100. It's three pulses at 250 kHz followed immediately by three pulses at 500 kHz. There shouldn't be any gap but the WAITSE1 doesn't fire until after a trailing period.
    		setse1  #(%001_000000 | tpin)   'set a rising edge event on the test IN (pin 4)
    		mov     ticks1, ##$0078_00f0    '240 clocks per pulse
    		mov     ticks2, ##$003c_0078    '120 clocks per pulse
    .main1
    'Test the choosen Smartpin
    		pollse1                      'clear possible pending event
    		wxpin   ticks1, #tpin        '
    		wypin   #3, #tpin            '3 pulses
    		waitse1                      'wait for final pulse
    		wxpin   ticks2, #tpin
    		wypin   #3, #tpin
    		waitx   one_sec
    		jmp     #.main1
  • evanhevanh Posts: 7,297
    edited 2017-07-17 - 22:35:04
    I think using a Streamer instead of any Smartpins would be more suited to driving a stepper. Streamers have the useful chained buffering as a hardware feature so, using DDS techniques, a single Streamer can handle multiple synchronised motors at once and even could do micro-stepping if you didn't mind throwing lots of pins at the job.
    In a similar vein, for individual Smartpins, it would be possible to manage chaining using timed, rather than event based, updates. Basically, change the X,Y parameters a few clocks before the previous pulse stream completes. Not unlike optimising HubRAM accesses. EDIT: Actually, that's exactly what ended up happening in the fastest Prop1 driver code, the WAITs were mostly thrown out in favour of counting instructions.
  • Hmm. That gap is really big (~720 clock cycles?) . I haven't set up my new PropScope yet, so can you try the timing variant instead of the event and see if the delay goes away? I'm curious if the delay is in the event part or the subsequent calls to WXPIN/WYPIN.
    edited 2017-07-17 - 22:48:44
    The problem is specific to that %00100 mode, and it's dependant on the period set in X. I chose a long period to highlight the problem. Mode %00101 is perfect up to its timing limit.
  • Here's the code for mode %00101. I don't have scope output on hand but it didn't even miss one clock tick as far as I could tell. Not until I reduced the transition period to 11 that is. Then I got an output of a whole extra static period at the new rate before the new transition count could be loaded.
    .main1
    		wxpin   #12, #tpin           '12 clocks per transition (60 MHz / 12 = 200 ns)
    		wypin   #5, #tpin            '5 transitions = 1 microsecond
    		waitse1                      'wait for final transition (X = 12 is minimum ...
    		wxpin   #30, #tpin           '... for appending to both parameters without any glitching)
    		wypin   #3, #tpin
    		waitx   one_sec
    		jmp     #.main1
    evanh wrote: »
    That does look broken.
    Did you check SPI Data flows, for gapless output ?
    ISTR talking with Chip about gapless UART/SPI, and he tuned the data paths to allow that (I'm rusty on exact final result)
    So it looks like the data path is buffered enough that it can do gapless, but the Control side may not be buffered enough ?
    From your notes before, it sounds like 12 SysCLKs is the control/command/config response delay ?
    That means %00100 should be able to reduce to that much gap ?
    Seairth wrote: »
    A delay that large, has to be data/state engine related - ie takes an extra whole or half of defined period, before accepting next command.
    If that can be fixed to the correct boundary, the gap can shrink to the time to apply a new command, I think was mentioned as 12 SysCLKs.
    Shrinking the gap right down to zero, would need to queue the commands, and I'm not sure how much logic that adds ?
    How important is this ?
    evanh wrote: »
    I think using a Streamer instead of any Smartpins would be more suited to driving a stepper..
    Even the streamer will have some Config-Reconfig delay ?
    It could be worth testing rapid FM modulation of NCO for streamer etc, to confirm that has no glitches or large gaps
  • JMG,
    You chopped off the reason why I said that: "Streamers have the useful chained buffering as a hardware feature so, using DDS techniques, a single Streamer can handle multiple synchronised motors at once and even could do micro-stepping if you didn't mind throwing lots of pins at the job."
    A Streamer can double/triple/quadruple/limited-only-by-HubRAM buffer to suit the application.
    evanh wrote: »
    JMG,
    Yes, but I was thinking about the time it takes the Streamer to change clock speeds.
    That's a config-side issue, not a data-flow issue.
    Or are you thinking of a single clock speed, and having massively duplicated data for lower speeds ?
  • No great need to change clocking at all. Just map the pulse rate like a bitmap, that's the DDS part. It might be both a tad processor and memory hungry though.
    edited 2017-07-18 - 05:32:10
    jmg wrote: »
    Yes, for synchronous motion, that's probably the sensible method.
    EDIT: Mode %00101 works fine for single channel stepper output. But then so does bit-bashing.
  • @evanh
    Here's what I found when using smartpins in transition mode.
    When you try to chain commands with new base periods the new base period is not set until the current base period has expired.
    	wrpin	#_trans,#tpin
    	wxpin   #90, #tpin
    	dirh	#tpin		'init smartpin
    	wypin   #2, #tpin	'2 transitions  @ 90 clocks
    	outh	#marker1
    	nop
    	outl	#marker1
    	wxpin   #15, #tpin	'4 transistions @ 15 clocks
    	wypin   #4, #tpin
    	outh	#marker1
    	nop
    	outl	#marker1
    	wxpin   #30, #tpin	'4 transitions @ 30 clocks
    	wypin   #4, #tpin
    	outh	#marker1
    	nop
    	outl	#marker1
    In the included screenshot the divisions are 30 clocks.
    I've included a "marker" pulse to show when a new smartpin command was issued.
    See how the second set waits exactly 90 clocks before starting and the third set starts 15 clocks after starting.
    I believe the base timer is a countdown counter and reloads when zero is reached.
    Toggling the smartpins DIR bit is the only way to reset the counter.
    From the docs
    Whenever Y[31:0] is written with a non-zero value, the pin will begin toggling for
    Y transitions at each base period, starting at the next base period.
    "starting at the next base period" seems to only be the case after a smartpin reset.
    798 x 164 - 57K
    Melbourne, Australia
  • ozpropdev wrote: »
    That's a good thing. That's exactly why I've been saying it's a clock perfect mode.
    I like the marker, does a good job of showing the timing of when the new segments are issued.
    From the docs
    I interpreted Chip's description as meaning it'll complete the previous period before reloading with the new value. And in your example, same for me, it only generates exactly what you defined. That seems ideal to me.
    evanh wrote: »
    I'm not clear here, how does the earlier image, which seems to show much more than a half-period gap, reconcile with ozpropdev's images ?
    ozpropdev wrote: »
    @evanh
    That sounds like what you'd operation to be - seems to give no unexpected gaps ?
    edited 2017-07-18 - 11:38:59
    My image is of mode %00100 "pulse/cycle output". Oz's is of mode %00101 "transition output".
    EDIT: Ah, when I said just in my prior reply to Oz, "same for me", I meant same for my own testing. I didn't mean same in my earlier snapshot example.
