Another ignition pick-up sensor question (with a diagram) — Parallax Forums
Capt. QuirkCapt. Quirk Posts: 872
edited 2017-07-13 00:42 in General Discussion
I recently replaced the stator on the msd ignition for the jet ski racer, it was a giant hassle
because the parts are no longer available. A few months later the control box failed.
I have been working on my own version of an ignition system using the propeller, and
since the other ignition system failed, I was thinking about using the stator sensors
from the other system to trigger my ignition system.
But I don't understand how the sensor works, because it does not seem to work like a
hall or reed switch.
The Control box provided a low voltage to the two wires that lead to the sensor. There
no grounds that I am aware of.
It is possible there is an smd choke coil inside the sensor with a concentration glued to the
top of the coil. If that is the case, could you power the choke with both wires? Or maybe
the 2 wires had pull up resistors inside the control box.
If both leads had pull-up resistors and they used a choke coil, how could the Propeller
sense a magnet as it passes by. It would create a sine wave right???
Would you use a LM339 comparator?
Thanks for your input.
  • That MSD unit uses a magnetic pickup. I would hook up my oscilloscope to the trigger pickup then pass a magnet over it quickly. Monitor the signal and come up with a substitute . The pickup is probaly a piece of iron core with a coil around it. They use this style pickup on their big block crank trigger.
  • Disconnect the pickup and measure the resistance with an ohmmeter it should be low 60-100 ohms.
  • You can still buy these new from MSD for about $700 pn 42351
  • Capt. QuirkCapt. Quirk Posts: 872
    edited 2017-07-15 04:20
    I took me a few days to retest the stator, and it has continuity.
    I know that MSD claims there is a coil in there, but from the two I am in the process
    of tearing apart, there is no normal pick-up coil inside.
    There is a small circuit board with a very small diameter sensor, that has a metal
    cone on top of it. Allegro called it a concentrator.
    Like I said before, it may have an smd choke coil inside with the concentrator mounted
    on top. The sensor is about 3/16" in diameter.
    If there is a really small pick-up coil inside, why does it require a small voltage on both
    wires from the box to the sensor?
    Bill M.
  • It could be an allegro ATS685
