PROPEEPROM Read/Write/Verify EEPROM 24xx32 - 24xx1026
zx81vgazx81vga Posts: 54
edited 2018-12-27 - 09:22:51 in Customer Projects
Hello Propellerfriends,
here is a new Project:
PROPEEPROM 1.0
320x240 VGA Text 16 Colors signaled as 640x480
SD/MMC
DS1307 RTC
PS/2 Keyboard
here to find:
http://propeller.ws-nbg.de/main.php
Greetings from Nuremberg, Germany
Werner
  • zx81vgazx81vga Posts: 54
    edited 2016-07-27 - 08:54:18
    here is an Update:
    PROPEEPROM 1.2
    Changes in v1.1
    24xx1025 added
    FC File Compare added
    Changes in v1.2
    24xx1026 added
    I don't have a 24xx1025 / 24xx1026 now. :frown:
    I ordered 2, but it take 2 Weeks... :frown:
    Can anyone test 24xx1025 / 24xx1026 with v1.2 ???
    Thanks for Feedback
    Werner
    edited 2018-12-27 - 09:01:22
    here is an Update:
    PROPEEPROM 1.4
    Changes in v1.4
    All ext. Data now in 1 File.
    Changes in v1.3
    Font now 160 Char's spare 192 Long's
    Screenshot removed spare 406 Long's
    Add Command "ERASE"
    Add Command "BLANK"
    Add Command "INFO"
    Add Command "CLOCK"
    Add Screensaver
    Have Fun...
    Werner
  • Thank you for your generous sharing of your projects.
  • Werner,
    Thank you for sharing your projects.
    Your Propeller Page is a delight to visit, and you deserve many more hits.
    Keep up the good work!
    edited 2018-12-27 - 09:17:11
    here is an Update: :lol:
    PROPEEPROM v2.0
    Changes in v2.0
    Add 16 Pin ZIF-Socket for 2 EEPROM's
    Add Command "PROBE" Detect 24xx32, 24xx64, 24xx128, 24xx256, 24xx512, 24xx1025 and 24xx1026
    Add Command "EECOPY" Copy EEPROM1 to EEPROM2
    Here to find
    Have Fun...
    Werner
  • PublisonPublison Posts: 11,438
    edited 2018-12-27 - 12:43:15
    zx81vga wrote: »
    PROPEEPROM v2.0
    Changes in v2.0
    Have Fun...
    Werner
    Very nice work, as always.
  • Nice looking project - I couldn't help noticing that there doesn't seem to be ceramic decoupling capacitors
    on both sides of the Propeller (or are they on the underside?)
  • @Mark_T
    I have build in 2 Electrolytic Capacitor's 0.1 uF
    one in Front (Pin 9 GND, Pin 12 VDD).
    one under the Propeller (Pin29 GND, Pin 32 VDD).
    Werner
    PS.
    I have no Capacitors in the Schematic. :confused:
    They are of course necessary.
  • Yes, but where are the ceramic decoupling capacitors? I wouldn't trust electrolytic above a few MHz, decoupling
    has to handle fast edges (5ns or less).
  • Cluso99Cluso99 Posts: 16,277
    edited 2019-01-06 - 04:19:04
    Not likely 0.1uF. Need 0.1uF ceramics.
