SimpleIde and PPDB
frank freedman
Has anyone run into problems with the load of the PPDB using SimpleIde? Simple IDE (Linux 1.1.1) works with Bare chip on breadboard, Activity Board, but not the PPDB. BST will work on all of these. Also noted that there seemed to be no selection for the PPDB in Simple IDE.
FF
rescue me output
propeller-elf-gcc -v GCC 4.6.1 (propellergcc-alpha_v1_9_0_)
propeller-elf-gcc -I . -L . -I /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/cmm/ -I /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -o Welcome.elf -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 Welcome.c -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm
propeller-load -s Welcome.elf
propeller-elf-objdump -h Welcome.elf
Done. Build Succeeded!
proploader -e -r -I /opt/parallax/propeller-load/ -b eeprom -p /dev/ttyUSB0 Welcome.elf
Opening file 'Welcome.elf'
Downloading file to port /dev/ttyUSB0
5576 bytes remaining
ERROR: Download failed: -1
Opening file 'Welcome.elf'Downloading file to port /dev/ttyUSB0
FF
rescue me output
Try a 1 or 2 and see if your load works.
dgately
As far as which board to use, I believe I used the Activity Board setting. I might have used "other"? It's just important to use a board setting that has a 64kB EEPROM and 5mhz xtal.
Tom
Results with path correction:
debtest@quantum:~/Prop_DEV/SimpleIDE/My Projects$ /opt/simpleide/bin/proploader -e -r -I /opt/parallax/propeller-load/ -b eeprom -p /dev/ttyUSB0 Welcome.elf
7640 bytes remaining
debtest@quantum:~$ simpleide
"SimpleIDE" argument count 1
Arguments:
"/opt/simpleide/bin/SimpleIDE"
Locale:
"/opt/simpleide/translations/SimpleIDE_en_US.qm"
Temp directory
"/tmp"
Mypath reassigned:
"/opt/parallax/"
Changed Line Edit for: SimpleIDE_Compiler
"/opt/parallax/bin/propeller-elf-gcc"
Value was:
My workspace reassigned:
"/home/debtest/Prop_DEV/SimpleIDE/"
My simple library path reassigned:
"/home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/"
Changed Line Edit for: SimpleIDE_Workspace
Value was:
Changed Line Edit for: SimpleIDE_Library
Value was:
Found Default Spin Compiler Path.
"/opt/parallax/bin/"
Default Spin Compiler:
"/opt/parallax/"
Default Spin Library:
"/opt/parallax/"
Changed Line Edit for: SimpleIDE_SpinCompiler
"/opt/parallax/bin/openspin"
Value was:
Changed Line Edit for: SimpleIDE_SpinLibrary
"/opt/parallax/spin/"
Value was:
Changed Line Edit for: SimpleIDE_SpinWorkspace
Value was:
Found Default Loader Path.
Changed Line Edit for: SimpleIDE_Loader
"/opt/parallax/propeller-load/"
Value was:
setEditor 1
clearTabHighlight Total Tabs 1 Total Editors 1 Current 0
"/opt/parallax/bin/../Workspace/"
pkwrk QDate("2017-07-01") QTime("23:50:08.155") 34621696
mywrk QDate("2017-07-01") QTime("23:51:34.190") 34707696
"/opt/parallax/bin/../Workspace/" is older
Set Key Value SimpleIDE_Library
Set Key Value SimpleIDE_Workspace
USB -1
Added "/dev/ttyS0"
enumerateports "/dev/ttyS0"
USB -1
Added "/dev/ttyS1"
enumerateports "/dev/ttyS1"
USB -1
Added "/dev/ttyS2"
enumerateports "/dev/ttyS2"
USB -1
Added "/dev/ttyS3"
enumerateports "/dev/ttyS3"
USB 8
Added "/dev/ttyUSB0"
enumerateports "/dev/ttyUSB0"
USB 8
Added "/dev/ttyUSB1"
enumerateports "/dev/ttyUSB1"
"/opt/simpleide/bin/proploader" ("-W")
QTextCursor::setPosition: Position '1' out of range
wxProcFinished "" 0 QProcess::ExitStatus(NormalExit)
currentTabChanged "/home/debtest/Prop_DEV/SimpleIDE/My Projects/Welcome.c" true "/home/debtest/Prop_DEV/SimpleIDE/My Projects/Welcome"
setEditorTab "/home/debtest/Prop_DEV/SimpleIDE/My Projects/Welcome.c" 0 Total Tabs 1 Total Editors 1
QLayout: Attempting to add QLayout "" to RescueDialog "", which already has a layout
Now for COG and Activity board FAILURE:
startProgram 0 time 0
"/opt/parallax/bin/propeller-elf-gcc -v"
startProgram 1 time 2
startProgram 2 time 3
startProgram 3 time 110
"/opt/parallax/bin/propeller-elf-gcc -I . -L . -I /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cog/ -I /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/cog/ -I /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cog/ -o Welcome.elf -O0 -mcog -m32bit-doubles -fno-exceptions -std=c99 Welcome.c -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm"
startProgram 1 time 1
startProgram 2 time 2
Now LMM and Activity board, build looked good, load failure:
startProgram 1 time 3
startProgram 2 time 4
startProgram 3 time 112
"/opt/parallax/bin/propeller-elf-gcc -I . -L . -I /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/lmm/ -I /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/lmm/ -I /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L /home/debtest/Prop_DEV/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/lmm/ -o cog/Welcome.elf -O0 -mlmm -m32bit-doubles -fno-exceptions -std=c99 Welcome.c -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm"
startProgram 3 time 59
"/opt/parallax/bin/propeller-load -s cog/Welcome.elf"
startProgram 3 time 56
"/opt/parallax/bin/propeller-elf-objdump -h cog/Welcome.elf"
startProgram 3 time 107
("cog/Welcome.elf", "-e", "-r")
"/opt/simpleide/bin/proploader -e -r -I /opt/parallax/propeller-load/ -b activityboard -p /dev/ttyUSB0 cog/Welcome.elf"
"Opening file 'cog/Welcome.elf'\nDownloading file to port /dev/ttyUSB0\n7640 bytes remaining \nERROR: Download failed: -1\n"
System info:
Linux quantum 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u1 (2017-06-18) x86_64 GNU/Linux
debtest@quantum:~/Prop_DEV/SimpleIDE/My Projects/cog$ /opt/simpleide/bin/proploader -v -e -r -I /opt/parallax/propeller-load/ -b eeprom -p /dev/ttyUSB0 Welcome.elf
Delivering second-stage loader
transmitPacket 8 failed - receiveDataExactTimeout
transmitPacket 8 failed - retrying
transmitPacket 8 failed - timeout
Edit: Do you have the 5mhz crystal installed? The second-stage loader depends on that.
Could be the default high-speed setting of the second-stage bootloader, try to slow it down to 115200 bps. To do so you need to edit with a text editor the .cfg file associated with the board you are using and specified with the -b parameter (in your case eeprom.cfg) and located in /opt/simpleide/parallax/propeller-load.
Add or replace the following entries (some may already exist with different values, make sure to replace all):
Now on to figure out why cog model can not find any of the simplex libraries..
Thanks for the load fix!!!
FF
Just so you know, that's in somewhat uncharted territories. I haven't tested any cog model programs with the Linux version of SimpleIDE. I would hope it works the same as everything else... but there's always a chance that it doesn't!
Tried welcome example. And couple others, random pick. Messages when choosing cog model appear unable to find any simple idea libraries. If I go into library directories, there are only libs for lmm and cmm. No other choices are selectable and no cog or other directories exist. Can I get the source to build them or a location of the compiled libs. Are they part of simpleide or propgcc? I am a bit rusty on C, and I have not found all of the workings of SimpleIde.
Thx,
FF
There are some examples under "Propeller GCC Demos" that uses cog mode modules, cog_c_toggle for examples. Generally, search for files with .cogc extension to find other examples as this is the extension that needs to be used to correctly compile for cog model. Beware that in cog mode you have only 512 longs for your program, I don't think any library will fit into that small space, cog mode should be used for low level drivers or other fast calculation needs.
Needing to update Debian to sid does not sound normal. I'll boot stretch up in a VM and see if I can reproduce that issue.
Now that you do have PropWare installed though, are you interested in just using its build system? It's reasonably solid on Linux since that's where I do my own work.
Actually I am going to use it, but will have a bit of learning to do for C/C++. The links you had to Cmake and make tutorial is 404 at this point, as are a nmber of other items that seemed like they would be useful. Been a while since I fooled seriously with make, and not used cmake. Packaging is always fun. Way back, I used perl at the tail end of the project build to create a fully automated solaris jumpstart load of the whole, OS and app. Be a lot of deep remembering and relearning to do that level of perl again.
I looked at Clion. Looks interesting enough, just not interesting enough to pay $80 a year for a license to tinker. Eclipse is free but cumbersome as /7734. A good IDE is nice to use, love BST, but no C in that one. gvim works well enough for me,though I am sure someone here will chime in about emacs...... Just need to remaster make/cmake.
And yes, thank you for all the good work you and others have put in here. I greatly appreciate it.
Thx
Btw, do a control + shift + R to refresh without cache if the page doesn't have "First-Time Setup of CLion" as one of the first headings.
