$6 OEM prop plug alternative — Parallax Forums
Though you could probably build-in to the board for $3-4, sometimes that is cost prohibited or to small parts for a DIY.
And by using FTDI pin-out standard, there will be multi-use.
http://www.mouser.com/search/refine.aspx?Ntk=P_MarCom&Ntt=197655408
