$3.41 Battery Capacity Tester
I just got mine today, now I can test my 10 AH Li-Ion cells' real capacity. http://www.ebay.com/itm/112336467549
What's the safe cutoff voltage under load for Li-Ions, 3.7V?
This guy gives this tester a thumbs-up: https://syonyk.blogspot.com/2015/10/zb2l3-v20-zhiyu-battery-tester.html
I ordered one from eBay.
Good reviews at Banggood.com...
http://www.banggood.com/ZB2L3-Battery-Capacity-Tester-External-Load-Discharge-Type-Module-p-1058571.html
Then realized that I've opened 40-some tabs of things to take a closer look at!
o.o
Keep 'em coming, erco!
I ordered one on April 5 and never received it. Sent the seller a message on May 26 but got no response yet.
Buyer beware!
Don't stop believing'!
I now have a 20Ω 10W resistor now on there to draw close to 0.2A from the smaller 2.5Ah LiPo, a closer match to its capacity and the use case. The gadget works well and I'll probably order a couple more. It would be easy enough to build something like it, but hey! not for that price. I set the cutoff at 3.1V, up just a bit from the 3.0V cutoff that the gadget uses as the default for what it determines is a LiPo. This if for instruments, not a motor. I want it see the usable capacity for a 3.0V low dropout regulator.
I ordered one from a different seller for $2.98...
Tracy - thanks for info about using the correct resistors
BTW mine measures right at 7.5 ohms.
I ran out of shelves many moons ago!
