Power switch
iseries
Has anyone designed a power switch that works like a tablet switch.
For example if you push the switch it powers on the Propeller and if you hold the switch for five seconds it powers itself off.
I have not seen any project like this and would like to build one. I thought of using a couple of MOS Fet switches to do the work.
The Propeller could also start a watch dog timer and if there is no activity it could power it's self off.
http://www.mouser.com/Semiconductors/Power-Management-ICs/Supervisory-Circuits/_/N-wnws/?Ns=Pricing|0
I have no idea about pros and cons of this solution.
Can someone here comment it?
I am not exactly sure how a tablet switch works, but I think this is what you might be looking for... forums.parallax.com/discussion/156184/discussion-of-latching-a-momentary-switch-to-control-a-power-supply#latest
The one that powers up the tablet with a simple push and reset it if you hold it down for 6seconds is there.
I sorted all by price, so keep looking until the first one does just that.
you learn something from looking at all those data sheets too.
Very tiny as for latest smartphones:
http://www.mouser.com/ProductDetail/Torex-Semiconductor/XC6190AN157R-G/?qs=sGAEpiMZZMunEhqKs81nFPBhTyRLN/sACxAqNzxo6yU=
http://www.mouser.com/ProductDetail/Microchip-Technology-Micrel/MIC2782DRYCS-TR/?qs=sGAEpiMZZMunEhqKs81nFLHEzlgNxanPcc/kqIIy9mo=
Some of them are in the Clock & Timer ICs category, this could work:
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FT3001MPX/?qs=sGAEpiMZZMsFq5dYAzx%2bAP98CwVzF87p1If7c/bJGf0=
On one side would be the Propeller such as pin 0. On the other side would be a momentary switch.
When pushed it would power on the Propeller and in code would make pin 0 high turning on the second fet.
when the button is released the unit would stay powered on. At any point the Propeller could power itself off.
I was also thinking that I might need some RC circuit so that if a reset were to occur it would hold the pin high long enough for the Propeller to boot up and take over again.
Could you reset system hang if you by mistake pull the pin low the first thing during boot up?
a endless reset cycle there you can not get in to reprogram the firmware? (until you desolder a part)
That is why tablet and phone manufactory use these reboot ic's
I can purchase two MOS fets for $.50.
TI also have power gating IC's
http://www.mouser.com/Search/Refine.aspx?Keyword=TPL5
For LDO with PG (powergood)
http://www.mouser.com/ProductDetail/Texas-Instruments/TPL5000DGSR/?qs=sGAEpiMZZMvARmQSk64rF8ksTkAGkThd
For LDO with Enable
http://www.mouser.com/ProductDetail/Texas-Instruments/TPL5111DDCR/?qs=sGAEpiMZZMvdy8WAlGWLcDBFGpzDUAXiydVgRsRjRxc=
You're a freaking rock star, I learn tons from your many posts. Thanks for carin' & sharin'.
Pololu has FET soft switches:
https://www.pololu.com/category/121/pololu-power-switches
https://www.pololu.com/product/751
FYI - Today is last day of Pololu's Memorial Day sale - the above mentioned switches are on sale 15% off
https://www.pololu.com/category/153/memorial-day-2017-sale
