Emic 2
I need some help in the complete code to make a song play on a basic stamp2/emic2. I always see this but not the complete code so I can learn how it all works.
This is not the complete song just part of it .
v5
S [:phone arpa speak on][:rate 100][:n2][:dv ap 200 sm 100 ri 100 f4 4600][ow<200,18>ow<200,15> sey<400,11> kae<400,15>nyu<400,18>w siy<600,23> _<300> bay<350,27> dhah<50,25> dao<400,23>nz rr<400,15>lliy<400,17> llay<600,18>t _<300> wah<200>t sow<200> praw<600,27>dlliy<200,25> wiy<400,23>hxey<400,22>eld _<300> ae<lldheh<600,18>r _<300> ow<400> sey<400,23> dah<400>z dhae<200,23>ae<200,22>tstah<400,20>r spae<400>ngel<400>d bae<400,25>nrr<200,28>rr<200,27>yxeh<200,25>eh<200,23>t wey<800,23>ey<150,25>ey<150,23>ey<1200,22>v _<900>fow<300,18>rdhah<300> llae<900,23>ae<400,25>nd ah<300,27>v dhah<300,28>friy<1000,30>iy<1000,35> _<900> ae<300,23>nd dhah<300,25> hxow<1000,27>m _<600>ah<300,28>v dhah<1000,25> brrey<1500,23>v _<900>][:n0]
  • Try the following code, which is a modification of the emic2 demo code with your song inserted into the section that demonstrates singing:
    '   File....... Emic2_Demo.bs2
    '   Purpose.... Demonstration of the Emic 2 Text-to-Speech Module
    '   Author..... Joe Grand, Grand Idea Studio, Inc. [www.grandideastudio.com]
    '   E-mail..... support@parallax.com
    '   Updated.... 10 SEP 2015
    '   {$STAMP BS2}
    '   {$PBASIC 2.5}
    ' -----[ Program Description ]---------------------------------------------
    ' This program provides a simple demonstration of the Emic 2 Text-to-Speech
    ' Module. Please refer to the product manual for full details of system
    ' functionality and capabilities.
    ' -----[ Revision History ]------------------------------------------------
    ' 1.0: Initial release
    ' 1.1: Added Select Voice command and a comment about BS2 missing the ":"
    ' response for commands that respond quickly.
    ' -----[ I/O Definitions ]-------------------------------------------------
    EMIC_TX	PIN		0		' Serial output (connects to Emic 2 SIN)
    EMIC_RX	PIN		1		' Serial input (connects to Emic 2 SOUT)
    ' -----[ Constants ]-------------------------------------------------------
    #SELECT $STAMP
      #CASE BS2, BS2E, BS2PE
        T9600       CON     84
      #CASE BS2SX, BS2P
        T9600       CON     240
    #ENDSELECT
    EmicBaud		CON     T9600
    ' -----[ Initialization ]--------------------------------------------------
    Init:
      DEBUG CLS, "Emic 2 Text-to-Speech Module Demonstration", CR, CR
      ' when the Emic 2 powers on, it takes about 3 seconds for it to successfully
      ' initialize. it then sends a ":" character to indicate it's ready to accept
      ' commands. if the Emic 2 is already initialized, a CR will also cause it
      ' to send a ":"
      DEBUG "Waiting for Emic 2..."
      SEROUT EMIC_TX, EmicBaud, [CR]
      'SERIN EMIC_RX, EmicBaud, 5000, No_Response, [WAIT(":")]  ' At 9600 baud, the BS2 misses the Emic 2's response for commands that respond quickly
      DEBUG "Ready!", CR
    ' -----[ Program Code ]----------------------------------------------------
    Main:
      DEBUG "Changing my voice..."
      SEROUT EMIC_TX, EmicBaud, ["N1", CR]   ' Send command
      'SERIN EMIC_RX, EmicBaud, [WAIT(":")]  ' At 9600 baud, the BS2 misses the Emic 2's response for commands that respond quickly
      DEBUG "Done!", CR
      PAUSE 250  ' Short delay
      DEBUG "Speaking some text..."
      SEROUT EMIC_TX, EmicBaud, ["S", "Hello. My name is the Emic 2 Text-to-Speech module. I would like to sing you a song.", CR]  ' Send the desired string to convert to speech
      SERIN EMIC_RX, EmicBaud, [WAIT(":")]  ' Wait here until the Emic 2 responds with a ":" indicating it's ready to accept the next command
      DEBUG "Done!", CR
      PAUSE 500  ' Short delay
      DEBUG "Singing a song..."
      SEROUT EMIC_TX, EmicBaud, ["V5"]
      SEROUT EMIC_TX, EmicBaud, ["S"]
      SEROUT EMIC_TX, EmicBaud, [:phone arpa speak on][:rate 100][:n2][:dv ap 200 sm 100 ri 100 f4 4600][ow<200,18>ow<200,15> sey<400,11> kae<400,15>nyu<400,18>w siy<600,23> _<300> bay<350,27> dhah<50,25> dao<400,23>nz rr<400,15>lliy<400,17> llay<600,18>t _<300> wah<200>t sow<200> praw<600,27>dlliy<200,25> wiy<400,23>hxey<400,22>eld _<300> ae<lldheh<600,18>r _<300> ow<400> sey<400,23> dah<400>z dhae<200,23>ae<200,22>tstah<400,20>r spae<400>ngel<400>d bae<400,25>nrr<200,28>rr<200,27>yxeh<200,25>eh<200,23>t wey<800,23>ey<150,25>ey<150,23>ey<1200,22>v _<900>fow<300,18>rdhah<300> llae<900,23>ae<400,25>nd ah<300,27>v dhah<300,28>friy<1000,30>iy<1000,35> _<900> ae<300,23>nd dhah<300,25> hxow<1000,27>m _<600>ah<300,28>v dhah<1000,25> brrey<1500,23>v _<900>][:n0]
      DEBUG "Done!", CR
      DEBUG CR, "Demonstration complete!"
      END
    ' -----[ Subroutines ]-----------------------------------------------------
    No_Response:
      ' if we get here, it means we did not receive a ":" from the Emic 2
      DEBUG "No response!", CR, CR, "Ending demonstration!"
      END
    ' -----[ End of File ]----------------------------------------------------
    I normally work with the emic2 using a propeller and its SPIN language, so the above code may or may not work, give it a try...
    Along with 'Antimatter' and 'Dark Matter' we've recently discovered the existence of
    `Doesn't Matter`, which appears to have no effect on the universe whatsoever.
  • I try running this code and as soon as it gets to the song part it gives me error codes. (Expected Constant,Variable,unary operator,or '('
    SEROUT EMIC_TX, EmicBaud, [:phone arpa speak ON][:rate 100][:n2][:dv ap 200
    Thanks Bob
  • Have you tried starting with the version of Star Spangled Banner in the EMIC2 Documentation?
    You have some parameters that may not be supported by EMIC2...
  • I have tried but I can't any of the DECtalk Parser codes to work. I know it is some simple command that I need to insert but just don't
    know what it is
    Bob
  • According to the EMIC2 Documentation the codes are only a sub-set of the DEC-talk codes...
  • I just can't get this code to work with a emic2 and a basic stamp2 every time it gets to the song playing line it gives a error
    Needs some help
    Bob
    edited 2017-05-09 - 17:02:51
    usabob01 wrote: »
    I see that you are trying to play the Star Spangled Banner -
    I think your problem may just be a syntax error in the EMIC data - look like you copied incorrectly.
    Specifically this piece "ae<lldheh<600,18>r> ...
    If the syntax is incorrect, you will get errors. Try playing small pieces that work and keep adding more data - if you get an error it will be easier to find..
    From the EMIC2 documentation:
    Singing “The Star-Spangled Banner”
    (The text exceeds the maximum allowable 1023 characters per message, so it must be split into two messages)
    [:phone arpa speak on][:rate 100][:n0][ow<200,18>ow<200,15> sey<400,11> kae<400,15>n
    hxey<400,22>eld _<300> ae<300,20>t dhah<100,22> tway<400,23> llay<400>ts llae<400,18>st
    glliy<400,15>m iy<200,11>nx _<300> hxuw<300,18>z brao<100,15>d stray<400,11>ps
    ae<400,15>nd bray<400,18>t stah<600,23>rz _<300> thruw<300,27> dhah<100,25> peh<400,23>
    rrel<400,15> ah<400,17>s fay<600,18>t _<300> ow<200,18>r dhah<200,18>
    rrae<600,27>mpah<200,25>rts wiy<400,23> waa<600,22>cht wrr<300,20> sow<100,22>
    gae<400,23>llah<400>ent lliy<400,18> striy<400,15>miy<200,11>nx _<300>][:n0]
  • That is what I need help on is to be shown a playable code that will play a song or part of a song on a basic stamp2/emic2 even if its only a short piece of the song.
    I realize it probably is just a syntax is incorrect but that's what I need is the correct programing to make it work. Just like the song above.
    I don't know how to make it play because I have not seen the correct lines of code to make it work on a basic stamp2
    Thanks for all your help
  • DaveJensonDaveJenson Posts: 256
    edited 2017-05-09 - 22:43:04
    <deleted>
  • Yes I tried Francis Bauer code and could not make it work.
    Bob
    edited 2017-05-09 - 22:55:02
    replace your line in the singing part with this from the Documentation:
    SEROUT EMIC_TX, EmicBaud, ["P0", CR]["S"rate 100][:phone arpa speak on][:n0][ow<200,18>ow<200,15> sey<400,11> kae<400,15>nyu<400,18>w siy<600,23> _<300> bay<350,27> dhah<50,25> dao<400,23>nz rr<400,15>lliy<400,17> llay<600,18>t _<300> wah<200>t sow<200> praw<600,27>dlliy<200,25> wiy<400,23>hxey<400,22>eld _<300> ae<300,20>t dhah<100,22> tway<400,23> llay<400>ts llae<400,18>stglliy<400,15>m iy<200,11>nx _<300> hxuw<300,18>z brao<100,15>d stray<400,11>psae<400,15>nd bray<400,18>t stah<600,23>rz _<300> thruw<300,27> dhah<100,25> peh<400,23>rrel<400,15> ah<400,17>s fay<600,18>t _<300> ow<200,18>r dhah<200,18>rrae<600,27>mpah<200,25>rts wiy<400,23> waa<600,22>cht wrr<300,20> sow<100,22>gae<400,23>llah<400>ent lliy<400,18> striy<400,15>miy<200,11>nx _<300>][:n0]
  • Thanks for the help Dave but I still get the Expected ':' or end of line error just after the ,CR on the second {
    edited 2017-05-10 - 02:14:37
    Ok - I attached a working BS2 program playing "Daisy"
    Don't forget the "S" at the beginning of "S[:phone arpa speak on]"....
    '   Updated.... 14 FEB 2012
    '   {$STAMP BS2}
    '   {$PBASIC 2.5}
    #SELECT $STAMP
        T9600       CON     84
      #CASE BS2SX, BS2P
        T9600       CON     240
    #ENDSELECT
    EmicBaud    CON     T9600
    Init:
      ' intialize. it then sends a ":" character to indicate it's ready to accept
      ' to send a ":"
      DEBUG "Ready!", CR
    Main:
    '  DEBUG "Speaking some text..."
    '  SEROUT EMIC_TX, EmicBaud, ["S", "Hello. My name is the Emic 2 Text-to-Speech module. I would like to sing you a song.", CR]  ' Send the desired string to convert to speech
    '  SERIN EMIC_RX, EmicBaud, [WAIT(":")]  ' Wait here until the Emic 2 responds with a ":" indicating it's ready to accept the next command
    '  DEBUG "Done!", CR
      DEBUG "Reset...", CR
      SEROUT EMIC_TX, EmicBaud, ["R",CR]
      DEBUG "Dectalk P0...", CR
      SEROUT EMIC_TX, EmicBaud, ["P0",CR]
      DEBUG "Singing...", CR
      SEROUT EMIC_TX, EmicBaud, ["S[:phone arpa speak on][:rate 200][:n0][dey<650,22>ziy<600,19> dey<650,15>ziy<600,10> gih<200,12>v miy<200,14> yurr<200,15> ae<400,12>nsax<200,15>r duw<750,10> _<400,10>][:n0][ay<600,17>m hxae<500,22>f kr ey<650,19>ziy<600,15> ao<200,12>ll fao<200,14>r dhax<200,15> llah<400,17>v ao<200,19>v yu<750,17> _<400,17>][:n0][ih<200,19>t wow<200,20>nt biy<200,19> ax<200,17> stay<500,22>llih<200,19>sh mae<350,17>rih<400,15>jh<150,15>][:n0][ay<200,17> kae<400,19>nt ax<200,15>fow<400,12>rd ax<200,15> kae<350,12>rih<400,10>jh<150,10>][:n0][bah<200,10>t yu<500,15>d lluh<200,19>k swiy<400,17>t ah<200,10>p ao<500,15>n dhax<200,19> siy<200,17>t ao<200,17>v ah<200,19> bay<200,22>six<200,19>kel<200,15> bih<400,17>llt fao<200,10>r tuw<800,15>][:n0]",CR]
      DEBUG "Done!", CR
      END
    No_Response:
      END
  • Works Great!!!!!!!!!!!!!!!!!! Thank all you nice and smart people for all the help. I am an old retired guy that still likes to learn new stuff.
    Thanks So Much!
    Bob
  • usabob01 wrote: »
    Thanks So Much!
    Bob
    From one old retired guy to another!
    :smile:
  • Here is the EMIC data to play Edelweiss - sounds decent
    S [:phone arpa speak on][:rate 180][:n0][:dv hs 95 br 0 as 90 ap 90 sm 90 ri 100][EY<800,15>DEL<400,18>VAY<900,25>S<300>EY<800,23>DEL<400,18>VAY<900,16>S<300>EH<800,15>VRIY<400>MOR<400>NIH<250,16>NX<150>YU<400,18>GRIY<1100,20>T<100>MIY<800,18>_<400>SMAO<500,15>LX<300>AE<250,18>N<100>D<50>WAY<1100,25>T<100>KLLIY<500,23>N<300>AE<250,18>N<100>D<50>BRAY<1100,16>T<100>YU<800,15>LLUH<300,18>K<100>HXAE<400>PIY<400,20>TUW<400,22>MIY<1000,23>TMIY<900,23>_<800>BLLAO<800,25>SAH<125,18>M<75>AH<250>V<150>SNOW<400,22>MEY<400,20>YU<400,18>BLLUW<500,15>M<300>AE<250,18>N<100>D<50>GROW<900,23>_<300>BLLUW<500,20>M<300>AE<250,23>N<100>D<50>GROW<800,25>FOR<400,23>EH<1200,22>VRR<800,18>_<400>EY<800,15>DEL<400,18>VAY<900,25>S<300>EY<800,23>DEL<400,18>VAY<900,16>S<300>BLLEH<600,15>S<200>MAY<400,18>HXOW<250>M<150>LLAE<250,20>N<100>D<50>FOR<400,22>EH<1200,23>VRR<800>][:n0]
  • Can anyone show me how to make this above song code work on a Ardino? Ron Czapala helped me get it to work on the basic stamp2.
  • ercoerco Posts: 19,419
    usabob01 wrote: »
    Wrong forum!!! :)
    There may be an Arduino forum somewhere with members as smart, friendly and helpful as you find here.
    But I doubt it. :)
    "When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
    - Pablo Picasso
  • usabob01 wrote: »
    I guess your Google button is broke? :)
    https://www.parallax.com/downloads/emic-2-arduino-example-code
    Infernal Machine
    DOH!
    We're REALLY friendly and helpful here!
    - Pablo Picasso
  • erco wrote: »
    usabob01 wrote: »
    Wrong forum!!! :)
    But I doubt it. :)
    Actually Parallax has an Arduino code example for the EMIC 2 here:
  • PublisonPublison Posts: 10,756
    edited 2017-05-16 - 15:49:24
    usabob01 wrote: »
    Wrong forum!!! :)
    But I doubt it. :)
    See two posts above. :)
    Infernal Machine
  • Publison wrote: »
    usabob01 wrote: »
    All that does is play you a song and does not show you the programing to play a DECtalk Parser song.
    Bob
  • erco wrote: »
    usabob01 wrote: »
    Wrong forum!!! :)
    But I doubt it. :)
    I thought because I was using a emic 2 I could get some help from you good guys.
    The example just plays you a song without showing you the programming of the DECtalk Parser song.
  • Publison wrote: »
    Opps! Missed that - sorry...
    edited 2017-05-16 - 17:16:36
    usabob01 wrote: »
    Bob
    Bob -it is same principle - you are sending a text string to the EMIC 2
    Just replace the first string with the second...
      emicSerial.print("Hello. My name is the Emic 2 Text-to-Speech module. I would like to sing you a song.");  // Send the desired string to convert to speech
      emicSerial.print("[:phone arpa speak on][:rate 200][:n0][dey<650,22>ziy<600,19> dey<650,15>ziy<600,10> gih<200,12>v miy<200,14> yurr<200,15> ae<400,12>nsax<200,15>r duw<750,10> _<400,10>][:n0][ay<600,17>m hxae<500,22>f kr ey<650,19>ziy<600,15> ao<200,12>ll fao<200,14>r dhax<200,15> llah<400,17>v ao<200,19>v yu<750,17> _<400,17>][:n0][ih<200,19>t wow<200,20>nt biy<200,19> ax<200,17> stay<500,22>llih<200,19>sh mae<350,17>rih<400,15>jh<150,15>][:n0][ay<200,17> kae<400,19>nt ax<200,15>fow<400,12>rd ax<200,15> kae<350,12>rih<400,10>jh<150,10>][:n0][bah<200,10>t yu<500,15>d lluh<200,19>k swiy<400,17>t ah<200,10>p ao<500,15>n dhax<200,19> siy<200,17>t ao<200,17>v ah<200,19> bay<200,22>six<200,19>kel<200,15> bih<400,17>llt fao<200,10>r tuw<800,15>][:n0]");
    and delete this line " emicSerial.print("D1\n");"
  • Thanks again Ron for the help. I tried I thought everything but the obvious. Your Tops!!!!!!!!!!!!!!!!!
    Bob
