Grab a few of these
$4.59 line follower kits before the price goes up, they were $4.36 when I bought on March 31. Once again, the sum of the parts is worth more than that! It's not programmable, just uses an LM393 comparator and two CdS cells to follow a line. Quick & easy build, works right away. It zigzags (alternating left/right motors) in its stock configuration, but I tweaked it and it's smoother & faster now. My video on top, someone else's at bottom.
"When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
- Pablo Picasso
BTW there are similar kits with IR obstacle avoidance and Bluetooth control.
http://www.ebay.com/itm/351962461760
- Pablo Picasso
XLNT. Maybe this becomes another Figure 8 type challenge with simple rules/guidelines, to do something new & different with this chassis. The price is right. Just one, Martin?
- Pablo Picasso
I am beginning to think that eBay sellers are watching for you to buy something, and then they raise the price for your followers
P1 Prop OS (also see Sphinx, PropDos, PropCmd, Spinix)
Website: www.clusos.com
P1: Tools (Index) , Emulators (Index) , ZiCog (Z80)
P2: Tools & Code , Tricks & Traps
- Pablo Picasso
- Pablo Picasso
- Pablo Picasso
We need translation! He spent five minutes talking about what seemed to be the bag the parts came in.
Many Ebay sellers don't ship to Italy since packages disappear in the mail. So this unboxing video is a rare treat from my favorite country, la mia Italia! If it's from Sicily, even better. Amo Sicilia!
- Pablo Picasso
Worm gear drive vs gearmotor assemblies
Phototransistor line sensors vs CdS cells
Microprocessor+comparator vs comparator only
H-bridges vs single transistor (fwd/reverse vs fwd only)
14500 Li-Ion battery vs alkaline
Bluetooth module (duh)
There may be a treasure hunt involved to track down the smartphone bluetooth tilt-drive app.
http://www.banggood.com/D2-6-DIY-51-MCU-Smart-Car-Kit-Bluetooth-Remote-Control-Gravity-Sensing-Tracing-Obstacle-Avoidance-p-1108390.html
- Pablo Picasso
Oh wait, maybe along with all the stupid emoji and color rendering they could add video animations into Unicode for Italian
(Don't tell them I said that, they are crazy enough to do it).
I used to chuckle at my Italian friend's frantic hand gesturing when he spoke to his family on the phone. "Sergio", I would say, "they can't see you hands moving". Oddly he did not do it so much when speaking English.
BTW the thumbnail shows my simplest mod yet for smooth driving. Cut trace to isolate IC pin 3, then connect pin 3 to the far side of R7.
- Pablo Picasso
erco-approved, nab one for yourself! This one has real H-bridges for reverse, the $5 version has forward only. IMHO this one is a great candidate for hacking, it might be the cheap merit bage robot people have been looking for. The sum of the parts is certainly worth more than $12. Kit comes with a preprogrammed STC15W201S processor. You can learn to program that (UGH) or chuck it and hack on your own favorite processor.
- Pablo Picasso
How should it work when it's off the floor and doesn't see a line?
- Pablo Picasso
- Pablo Picasso
- Pablo Picasso
Changing both resistors R7 and R8 to 470 ohms would probably make adjustments easier.
- Pablo Picasso
Calibration procedure for the one-wire mod shown in the schematic 3 posts back:
The only downside of this simple mod is that adjusting the modified LFR is trickier than the stock unit and requires empirical calibration, i.e., experimenting! Calibration depends on the battery voltage and the physical position of the LEDs and photocells which are hanging out in space and vulnerable to bending, so be careful not to crash or bend them. I run my photocells ~ 0.100” AGL and the LEDs ~0.200” AGL. Use the small oval course printed on the back of the instructions to calibrate. Start with both pots adjusted to their center position. Per Figure 7, the left pot MOSTLY adjusts the right turns and right pot MOSTLY adjusts left turns, although they affect each other and you need to strike a balance. Calibration is an iterative process where you test a right-turn circle (clockwise) and slowly, slightly adjust R2 counterclockwise until it follows the turn properly. Then test a left-turn circle (counterclockwise) and slowly, slightly adjust R1 clockwise until it follows the turn properly. Then go back and retest right and left turns. There is a best balance of pot adjustments which will let the robot track properly right and left. Once you get it dialed in, you can try speeding it up. One of my videos shows that faster speeds come from using higher voltage Li-Ion cell (~4V) compared to the stock 3V alkaline cells (recalibration required). How fast can YOU go?
- Pablo Picasso
No idea. But the last time I had an issue like this, the components were defective (LEDs manufactured backwards - so the flat side went to the wrong pin!)
- Pablo Picasso
- Pablo Picasso
Jameco is nearby and another chip is only $0.25. Will pick one up in the next day or two.
- Pablo Picasso
Pin 7 -> GND works (same side as works with the chip in)
Pin 1 -> GND does not. When grounded the LED flickers briefly.
So at this point the chip isn't the culprit. Is that the transistor then?
