$1.40 Microwave Radar Sensors
Are you kidding me? Just heard about them here and ordered three.
http://www.ebay.com/itm/112160912972
No directional capability.
Perhaps that can be fixed by building it into suitable dish/reflector.
What little info I found on the original lfs-dc04 module says that it has an omnidirectional range of several meters. Output goes high for 30 seconds when triggered by motion, like some PIR sensor modules. I found a Youtube video with an offensive start so I won't link here.
I think their intended use is automatic door opening sensors - they are mounted up over the door and can 'shine' through plasterboard or similar - they sense, typically, people walking in the vicinity of the door so that the door can be triggered to open.
Maybe the cheaper omnidirectional ones (which according to the write up do have a high level output) are intended to turn on lights when people enter a room or similar. The fact that they have a cadmium sulphide light detector built onto the board makes this likely - so that the lights need not be switched on if there is already daylight in the area. Looks like they may be a radar alternative to the more normal passive IR sensors used to switch on porch lights and similar.
At first glance, I don't understand the need for the photocell, STOP
EDIT: Well I'm glad someone else asked first.
You are not being as thrifty as usual.
Here is one for $1.01
http://www.ebay.com/itm/LFS-DC04-2-7GHz-Microwave-Radar-Module-DC-5V-360-Degree-High-Level-Signal-Output-/311713408338?hash=item4893912552:g:ffUAAOSwpLNX9p15
or if you want to solder the LDR yourself to save a cent ($1.00) then here
ebay.com/itm/LFS-DC04-2-7GHz-Microwave-Radar-Module-DC-5V-360-Degree-High-Level-Signal-Output-/182419142635?hash=item2a790737eb:g:AoQAAOSw2xRYd1Vw
BTW, Iam wondering about the LDR too. Could it be used for the aerial perhaps???
Postedit: Google is your friend. It is an LDR and only works during the dark.
https://youtube.com/watch?v=lr9HxnSiLig
Remove the LDR to work day and night - so the $1.00 is the easiest to use!!
$1.01 plus Shipping: $1.85 ePacket delivery from China
or for the DIY LDR version:
$1.00 plus $2.00 ePacket delivery from China
But I'm distracted playing with my first ESP8266 so I might be slipping.
Both are free shipping to Oz
Jim
The photocell is probably as a safety for use in door opening/closing schemes. Kirk and Spock would have appreciated these on board the Enterprise for when the doors didn't work right. Technology of the 23rd century was a little lacking.
You could probably make a focusing cavity for one of these, but you'd need to get the numbers right for any hope of it working.
Oh, and I suppose you could use these to make cameras. Just a thought.
I tried to build a cheap long-range collision avoidance system with a simple bump switch on a 200-foot bamboo pole ahead of the car. Worked fine on the freeway but it kept fouling in city traffic.
The GHz oscillator uses PCB tracks to make the necessary inductors and capacitors, so it's frequency is neither precise or stable, but that doesn't matter. The original purpose for these modules is controllers for room lighting, so there are lots of them, and they are cheap.
A really cool attribute is that they can be mounted inside a plastic box, with no lens or window needed. Great for hidden detectors.
Here is a write up :
https://github.com/jdesbonnet/RCWL-0516/
and if you want a different shape :
http://www.ebay.com/itm/1PCS-LED-3-1...UAAOSwIgNXjfD7
Ah. So not really "legal" to operate in this country. Not sure how much variance the FCC allows for S-band, but parts are used for broadcast, so there probably are limitations. A few thousand Hz probably wouldn't hurt much, but inching down toward 2.4 GHz will screw with a lot of cordless phones. And I know you still use those in the Erco household...
Hey, for $1.40, simple rocks!
From what little I can gather.
Just needs more range, better focus, and possibly sights. Most old radar units did not have sights, just point and ticket.
Here is a nice breakdown and enhancement hack for cheap radar modules.
Me too. Three of them arrived today.
Me too. Now why did I buy these?
Interesting stuff. Thanks for posting the link.
Yeah... I ran across that one too. How rude! :-| (And that was the only one I found. Seems simple enough tho'.)
You mean how those two SMT resistors could have been soldered on two ways or left off?
Probably to adjust for different DVD regions, NTSC vs HDMI vs UCLA.
Sweet, I needed PAL, pal.
I removed the light sensor and they work. I setup a cheap PIR detector alongside, and the PIR is much more sensitive.
It doesn't seem to detect anything moving very slow, unless it's right in front of sensor. That is interesting to me, because if it were on a slow robot, it could provide motion detection (things moving faster than the robot) while the robot is moving. That's something not many sensors can do, so I'm going to explore that some more.
It's hard to see the traces on the board, but I have the datasheet for the chip and will try to figure out the jumpers.
