Need to find, lost. — Parallax Forums
Need to find, lost.
I had to go over to a backup SD Card on my Raspberry Pi, and I do not have the links for OpenSpin and PropLoader (either the precompiled RPi versions or the source versions). So links would be of help.
Also is there a way to get the Propeller Font working with ARM Linux? I do NOT use the PropellerIDE, I use either xedit or leafpad to edit source, and a terminal to compile and load.
