2-bit gui
Rayman
So, the 4-bit gui seems workable. But, I wanted to try a 2-bit gui before going all in.
2-bits lets us use P1 ROM font and allows higher resolutions.
The font also looks smoother than with the 4bpp mode because the characters are 16x32 instead of 8x16.
This is just a test at VGA and XGA resolution (tested on P2V13, but think will work on P2V15 too):
2 bits can be effective.
With P1, I did a block cursor, the size of a character, where I basically just inverted and jumbled the colors so you can see where it is.
Would really like to do an arrow, but not sure if it's possible...
Nothing wrong with a block cursor. Very easy to see, particularly if you toggle between inverted/non inverted colors when it is over a character.
I'd agree, text editors use vertical strip or underscore or block cursors, all are ok for char-based cursors.
A problem with an arrow cursor, is users will expect single-pixel resolution - unless that is what you intended to try ?
But, since the screen is buffered, I could make things like a drawing/Paint app with 4 colors...
Also, could identify the pixel clicked on in an image.
But, I guess I should think about these adverse affects of arrow and see if that would cause more pain than it helps...
One way is to add it in as the pixels are put on the scanline. You do the computation during blank, set counters and pointer to mouse pixel data.
On count condition being met, two character pixel data gets fetched, then the mouse data gets added.
Another way is to buffer 4 characters. This little buffer is for the mouse and whatever text is under it.
On each blank, grab the 4 under the mouse, combine them with the mouse and substitute them into the bit stream when it's time.
For bitmap, it's just counters. Buffer one line always. On blank, and on count, write the arrow into the buffer before it gets streamed.
That's a two byte read, mask in arrow, write back out. An xor arrow can work nice, as can one that actually picks one single pixel above the tip of the pointer graphic. Most people will get used to this.
Was just playing with introducing immediate xcont commands into the scanline.
Looks like the buffering will let me do two single pixel xconts.
So, appears a single color cursor might work.
Think it's because XGA pixel clock is faster than 40 MIPS.
At 80 MIPS, might be able to do arbitrary colored cursor, for xga anyway.
Edit, I didn't see tiles. Yup. Somehow I was thinking 2bpp whole screen.
The xcont is interesting! Novel thinking there.
An example of monochrome pointer. Just for grins.
First line is one pixel of white, that's OK.
Second line is the problem. One white, one black and then one white again...
Was thinking about colors. Truth is, let the pointer change.
A single pointer color can work when it's different from the others.
From there, let the people decide. They get three per tile. Or pointer changes. Planning for that isn't tough to do.
SGI had a bright red pointer. Worked well almost all the time.
And don't the Parallax fonts use %00, 10, 01?
Small 4x4 pixel block. A corner is the tip. Same size cross hair. Those are very unobtrusive. Should work with the two pixel limit.
Can you show me a code snippet of doing the xcont?
Problem is that even if I tell it to do less that 16 pixels, the pixels always come from end of the long and I need to shift them...
For this to have any chance, I'd need to change from xcont RFLONG LUT mode to separate RFLONG and xcont Immediate commands, with some shifts in between...
Maybe that doesn't work, have to see...
When you get to a pointer line, use a different draw loop, and in it, change depths for part of that line, or maybe the whole line, and only need a small buffer and would have a lot of time to do it.
That way, you have the extra colors needed. If you used 4bpp, it would all work out and you could do a nice pointer, outline and all, if you want.
This is puzzle with 80 Mhz clock though.
Think I'll see if I can rotate pixels where I need to during vertical refresh...
My two-tone cursor was only 13 pixels at widest point though.
With that each xcont from buffer would always take at least one pixel, I think.
A block around a two color cursor spanning at most 6 tiles would need at most 26 colors.
Could use the currently free values in first 256 longs of LUT to hold these colors.
Then, create this say 13x20 pixel block of 8-bpp LUT in cog RAM.
Use the xcont LUT 8bpp immediate mode to
The cursor pixels in 13x20 block would be static, only need to change the background pixels to match the screen...
Actually, 12x20 would be more convenient as it's three longs wide...
Also seems to me, one could set this all up on a nice, even tile boundary by just shifting the pointer too, should timing get funky. This does mean buffering the pointer somewhere, but it also might break down per tile nicely too. You never have a quick change, relative to the instruction speed.
Four draw loops, potentially.
One normal one, non pointer lines. (2222222222222222222222)
One two segment, higher bpp, then 2bpp. (hhh22222222222222222)
One other two segment, 2bpp, then higher bpp. (22222222222222222222hhh)
One three segment, 2bpp, higher bpp, 2bpp. (2222222hhh222222222222)
And maybe it's just two: Normal, and segmented. Seems like there is time to make that conditional, but this is worst case.
I did test changing streamer color depth mid scan line some time back. It worked, but a bit of scanline time could get lost, depending on when the streamer ended and the next instruction to fire it off again happened.
Sent that one to Chip, and the answer was a double command buffer to insure streams happened back to back.
But I think I have it...
You can see in the image a 2x2 tiles area that is replaced by 4bpp data (the red, yellow, white, blue bars near the bird's head).
Tried really hard to make 8bpp cursor work, but just not enough clocks...
4bpp may work out really well anyway as the colors are divided into 16 sets of 32 colors.
The first four colors in each set are used for displaying the 2bpp tiles. That leaves 28 colors that can be used for the cursor. I'm planning on just copying those 28colors to all 16 sets.
Then, I can use the same set that the tile would have used for 2bpp buffer with the 4bpp cursor on top of buffer data.
Next question is if there is enough time during vertical refresh to construct the 4bpp cursor area... If not, I'll have to bring in another cog to do it...
Really need to turn 2bpp P1 interleaved font into 1bpp non-interleaved font.
With only 16 sets of colors, don't want to use 2 sets for each fore/back color combo.
With 1bpp font, can have many more color combo options...
Looks nifty.
I would think there is, plus real cursors only move sporadically, so have a number of options..
* You could spread the render over more than one frame, with priority given to the cursor element
eg Google earth renders in more than one pass.
* You could use interrupts, so the scan stuff gets priority and the cursor background render is done using lower priority sysclks, when available.
* A quick check for 'no movement or changes' would skip the render update. Mostly, this path is taken.
Right now, it shows a red cursor that jumps around on the screen.
This method gives 28 available colors for the cursor. What's even better is that I can use 4 of those colors to create a darkened version of all the 2bpp colors. This allows for a cursor that casts a shadow, just like newer versions of PC OS do.
Anyway, this is about a million times more complex than a block cursor, but I think it's worth it...
What is the code size and cycles overhead for running this advanced cursor ?
BTW: The other nice thing about doing the cursor this way is that I'm not messing with the underlying 2bpp screen buffer. That is nice because I don't have to suspend the cursor when drawing on the screen, like have to with my 4bpp driver.
Also, might be able to bring in Chip's P1 graphics code...
Can do windows and buttons with P1 rom font.
Can also make shadows.
Cursor can work.
Now, have to think about 2bpp gui versus 4bpp gui...
That screen image is looking really good.
