Stamp Stack 2P Experimenter's Board
microcontrollerusermicrocontrolleruser Posts: 556
edited January 13 in BASIC Stamp Vote Up0Vote Down
Developers
How do you place this on breadboard?
If I put it on bottom right the 2 pair of 2pin headers on bottom seem to
be a grounding hazard.
It's a Parallax medium breadboard. 660 tie point as far as I can tell. Kind of an oddball size.
Thanks!
JUNIOR ENGINEER
AMATEUR ASSEMBLY PROGRAMMER
  • 58 Comments sorted by Date Added Votes
  • That is not a Parallax Board, so you would have to get support from Soloarbotics.
    https://content.solarbotics.com/products/documentation/stamp stack 2p v2.3.pdf
    Infernal Machine
  • PublisonPublison Posts: 9,823
    edited January 13 Vote Up0Vote Down
    Developers
    Thanks!
    Got a picture of what does not line up? Parallax only sold standard breadboards.
    Infernal Machine
  • Mike GreenMike Green Posts: 22,584
    It looks like there are 20 pins in a row: digital I/O pins 0 to 15, then the four analog pins. The +5 and ground pins are marked as #9 on figure 1. Presumably this plugs into a breadboard of at least 20 pins with a separate +5 and ground bus on the sides. The two 2-pin headers plug into the power bus on the side. They don't just hang down.
    Look at this breadboard from SparkFun. It has the power bus, but only has 30 rows of contacts, enough to use with this board, but not too useful otherwise. Get a bigger breadboard or 2 or 3 of these.
    https://sparkfun.com/products/12002
  • Publison, Mike
    This breadboard.
    https://www.parallax.com/product/700-00078
    When you put power pins in side power rail the
    pins end up in the IC 'ditch'.
    When you hang it off side (signal pins in far right column) the
    power pins are just out there.
    You would have to connect 2 pin extension cable from bottom.
    Thanks!
    JUNIOR ENGINEER
  • Infernal Machine
  • Publison
    P24 does not line up on breadboard with power connectors
    in power rail. Period.
    Get it done solution is to use two breadboards.
    One for I/O pins and one for power output.
    Board can actually just be tested on top of anti-static bag.
    I want to protect it though.
    This is a great board!
    Thanks!
    JUNIOR ENGINEER
  • Mike Green
    I don't know if your saying connect power pins to
    separete power rail breadboards.
    Anyhow we're just going to power it up and
    make sure Stamp Editor identifies it first.
    Be fun selecting P24 micro and 2.5 language!
    Thanks!
    JUNIOR ENGINEER
  • If you're unsure about your setup, you might want to post a picture of it here before powering it on and potentially damaging something.
  • microcontrollerusermicrocontrolleruser Posts: 556
    edited January 14 Vote Up0Vote Down
    Electrodude
    Picture is in manual that Publison posted above.
    It's kind of beyond a module.
    Guess the idea was popular for awhile and
    now it isn't.
    Guess they figure the technically savvy can just build the
    whole thing from scratch on a breadboard.
    I like my little 'PCB on a breadbord' p24.
    Thanks!
    JUNIOR ENGINEER
  • This is very odd. How could they be selling this for only $4? Did they somehow clone Parallax's OEM p24 chip?
  • GenetixGenetix Posts: 1,048
    edited January 15 Vote Up0Vote Down
    microcontrolleruser,
    Save yourself the grief and get one of Parallax's kits which have everything you need and are ready to use out of the box.
    The BASIC Stamp Activity Kit is the best bang for the buck at $80.
    https://www.parallax.com/product/90005
    The BASIC Stamp Discovery Kit costs twice as much but it comes with the BASIC Stamp Manual and the Board of Education can also be powered from an AC adapter and the BS2 module can be changed.
    https://www.parallax.com/product/27807
    David,
    The breadboard is $5.
  • Genetix wrote: »
    David,
    The PDF says it includes the BS2p24 chip.
  • Genetix
    This is totally different kind of board,
    It doesn't come with training wheels.
    It's for hard core techy's.
    It's from back when Parallax catered to that crowd.
    Mr Betz
    This Stamp Stack is a very very old board.
    Solarbotics got tired of looking at them on their shelf and clearanced them.
    At one time HVW had a relationship with Parallax.
    Kind of like the Neurve outfit.
    By the way Neurve site has some interesting stuff on it.
    Thanks!
    JUNIOR ENGINEER
  • Developers
    Okay. Back to business.
    Battery they included for on board clock has 3 volts.
    This takes an old D type usb cable.
    There is barrel jack power only, no battery.
    It has a serial port, rj45 and provision for additional Ram.
    512 memory can be added as is, if you want one megabyte you
    have to break a soldering bridge.
    Thanks!
    JUNIOR ENGINEER
  • Mr Betz
    Thanks!
    Okay, thanks for clarifying. I guess this board has an actual Parallax chip on it. No cloning involved.
  • David Betz wrote: »
    Mr Betz
    Thanks!
    Looks like a BS2P24 Interpreter chip.
    Just ordered a couple. Let's see if they are in stock. Not bad for the price.
    Infernal Machine
  • David Publison
    When I connected it it did a Windows 7 'installing drivers' popup window.
    Long story short, did not identify in Stamp Editor.
    Will contact HVW monday about location of drivers.
    They've morphed into Avorobot.
    Thanks!
    JUNIOR ENGINEER
  • Try these drivers:
    https://www.parallax.com/downloads/parallax-usb-driver-installer
    Reboot computer after installing.
    Infernal Machine
  • Publison
    Thought they were already on there.
    Will double check with a regular stamp board.
    Solarbotics p24 page has drivers down the bottom.
    Board may take a driver too.
    Hardware wise the green led lit up after plugging 12v power supply in.
    Thanks!
    JUNIOR ENGINEER
  • Publison
    Thanks!
    The driver I linked on the Parallax site are the latest FTDI drivers. (FTDI USB is used on the Solarbotics board). The Solarbotics drivers are from 2004 and supported Win98 and Win2000. The Parallax drivers may be a better choice.
    The only driver the board needs is the FTDI USB drivers.
    Infernal Machine
  • Word of advice re updating/reinstalling drivers. It's good practice to uninstall the old drivers before installing the new ones. Had several occasions where installing a new driver over the old one created intermittent problems. I suspect some leftover from the old driver was the cause. At that point it was too late to uninstall the old driver, and uninstalling/reinstalling the new one did not help.
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
  • kwinn wrote: »
    Good point. Always uninstall FTDI drivers, even though you are installing the same. You just never know what's left over.
    Infernal Machine
  • Developers
    Thank you for tips!
    Give it another shot tomorrow.
    Thanks!
    JUNIOR ENGINEER
  • Developers
    This board has an RJxx, serial and USB connector on it.
    Can the RJxx and serial connectors be used for programming?
    Thanks!
    JUNIOR ENGINEER
    Chris Savage | Engineering Tech | Main Office: (916) 624-8333 | Direct to Tech Support: (888) 997-8267 | Website | Twitter | Google+
  • Chris
    Can't find the little manual that came with it right now.
    These two say 'Programming' in your pic there:
    Serial
    USB
    The RJxx says 'I wire interface'.
    Interface usually means communication so it
    is not for programming?
    Don't want to fry board.
    Thanks!
    JUNIOR ENGINEER
    edited February 6 Vote Up0Vote Down
    Many BS2p-based development boards used to have the RJ-11 connector for the popular 1-Wire interfaces of the day, such as the one shown below (Blue Dot Receptor/iButton):
    P.S. - The manual was a Google Search away. :innocent:
    http://content.solarbotics.com/products/documentation/25055-manual_v21.pdf
  • Chris
    PIC or AVR uses some kind of RJxx for programming but I think that's a
    recent change.
    Okay, got it.
    Appreciate it.
    Bob
    JUNIOR ENGINEER
  • Chris
    Serial
    USB
    Thanks!
    The full manual in in post #2 of this thread.
    Thanks for resurrecting this thread because I was wondering where my product was. Well, low and behold, it just put in my mail box!
    I'll break it out tomorrow and see if I can answer some questions.
    Infernal Machine
    Chris
    Serial
    USB
    Thanks!
    One Wire is for a class of peripherals:
    https://www.maximintegrated.com/en/app-notes/index.mvp/id/1796
    You can use a USB connection or Serial Connection to program the Basics Stamp, per the instructions. I will check both interfaces tomorrow.
    Remember, this is not a Parallax product, so support is through forum members, if they can help .
    Infernal Machine
