A little C Help needed. — Parallax Forums
NWCCTVNWCCTV Posts: 3,629
edited 2016-07-20 14:21 in Learn with BlocklyProp
I really wish SimpleIDE had support for the ESP 8266 module. Any how, I have this code that works great for one Servo but I am having issues getting 2 or more to go. Can someone look at this code and let me know what to do to run more than one servo?
Servo servo;
Servo servo1;
void setup()
  Serial.begin(9600);
  Blynk.begin(auth, "XXXXXXXX", "XXXXXXXXXXXX");  // replace with your WiFi router details
  servo.attach(15);
  servo1.attach(10);
BLYNK_WRITE(V15)
BLYNK_WRITE(V10)
  servo.write(param.asInt());
  servo1.write(param.asInt());
}void loop()
 Blynk.run();
  • Never mind. I solved it on my own!!!! I am leaving the code as is in case anyone else ever has the problem. What I found was that I did not need to initialize the second servo, servo1 pin: BLYNK_WRITE(V10)
    It would sure be nice to see Blynk and others support Parallax products. As technology advances, it seems that Parallax is being left behind and not included in any of the nifty Apps out there.
  • Since this is one of my IOT projects, I am going to close this and start up a discussion there: http://forums.parallax.com/discussion/160437/iot-in-my-home#latest
