Welcome to the Parallax Discussion Forums, sign-up to participate.
'Detect available smart pins on FPGA 'Returns total number of available smart pins 'and a 64 bit mask indicating active smart pins. dat org sp_detect rep @search,#64 'test all 64 pins mov dirx,#dira testb smart_pin,#5 wc 'pin 0..31 or pin 32..63? setbc dirx,#0 'dira/dirb select wrpin #%11_0,smart_pin 'long repository mode altd dirx,#0 'set port setb 0-0,smart_pin 'enable smart pin mov pattern,##$c0ffee00 add pattern,smart_pin 'unique pattern wxpin pattern,smart_pin 'write long to smart pin nop 'allow time for smart pin write (needed!) rdpin response,smart_pin 'get long from smart pin repository cmp response,pattern wz 'valid response? if_e add available,#1 shr mask_msb,#1 wc 'build valid smart pin mask rcr mask_lsb,#1 setbz mask_msb,#31 wrpin #0,smart_pin 'disable smart pin altd dirx,#0 'set port clrb 0-0,smart_pin 'reset smart pin add smart_pin,#1 'next smart pin search or dirb,##$ffff 'show result on leds (P123-A9/DE2-115) mov outb,available done jmp #done pattern long 0 dirx long 0 response long 0 mask_lsb long 0 mask_msb long 0 smart_pin long 0 available long 0
Chip gives that info on a reset but I don't know how you can access that info. Probably in the small serial ROM.
