$3.50 Ham Transceiver Kit
Why not? At that price, it's worth it just for the soldering practice/therapy. I got two for the twins, natch.
http://www.ebay.com/itm/321913864124
You and me both, Brother! I wonder if a simple wire or whip is sufficient for a few hundred feet.
Agreed, the rx sidetone is likely whatever the difference is between the two crystals. I didn't bother explaining about CW and sidetone since it's a ham-only frequency and hams know all that stuff. Not that anyone would crack down on these microwatt transmitters. I'm guessing that for the most part, TVI is a thing of the past in this hifi wifi bluetooth hi-def hi-res blackfin quad core digital age.
If the piece of wire isn't short and the band conditions are decent, you might get a few hundred MILES, not feet. It's not likely to cause TVI, but be careful about unlicensed operation. Your neighbor won't hear you, but on the 40m CW band, a lot of other people might.
Eons ago I was naively testing a 40m CW transmitter using a light bulb on my desk as a dummy load. The rig produced a bit more power than these little boards(~20W, IIRC), but my "antenna" was the light bulb and a few feet of zip cord. I was stunned to hear my callsign coming out of the receiver when I got a call from a ham roughly 300 miles away who heard my test. I never used a light bulb for a dummy load again.
Edit: Long ago that was actually a common thing to do if you didn't have the spare cash for a Heath Cantenna. These were tube transmitters with pi-network outputs, and they were surprisingly capable of matching poor loads. Besides, is it really that crazy? I think I used a 100 W bulb. Driving it with 110V RMS, R = V^2/P so in really round figures that's 110 squared over 100 or about 120 ohms when the filament is hot and it's mostly resistive. That's less than 3:1 VSWR. Not good, but not that awful.
I finally let my licence lapse about 4 years ago since I hadn't been on air for >20 years.
Of course now there are the SDR's around I could get interested again. Then again maybe my time is better spent with prop things
Sure, and how to know how much was heat and how much was RF I have no idea*. Probably mostly heat as you suggest. The whole point was to suggest that it doesn't take much power, nor much of an antenna, to radiate a signal so some care is in order. I should've figured Erco would have a ham license and knew that anyway.
Maybe we need to figure out some way to combine Props and ham radio.
*Edit: I suppose some sort of improvised calorimeter might work if anyone were interested enough to try it. I think I'll just avoid light bulbs as antennas
Sounds like we may have had the same Heathkit rig, the DX-60B! Still have mine, along with the matching VF-1 for and HR-10B receiver . And that light bulb dummy load trick was recommended in the build manual.
Me thinks you were a HAM long before you got a license.
If Heathkit recommended the light bulb, I feel vindicated.
We had nearly the same station! DX-60 (borrowed from my uncle) and HR-10 (that I saved up for a year to buy). Inverted-V antenna for 40 and 15 meters. Replaced the DX-60 with a Johnson Viking Ranger when I got my general ticket. Then I sold it all, along with a teleprinter, to my former HS math teacher when my license lapsed.
AD7YF (former WA9HJK)
-Tor (who has lost count of the number of erco-initiated items he bought. But today the secretary at work replaced his mailbox with one three times bigger.. there wasn't enough room when several small shipments arrived together, so she decided to fix the problem.)
Hah! I was wrong. As assembly began I realized they were using a 1N4001 as a varactor diode to push the crystal a bit. In minimalist designs things aren't always as they seem. And many times a part serves double duty.
BTW, in the kits I received the 1K resistors were missing. Not a problem though...
(What _is_ a problem is what to do with all the R's C's L's and Q's I'll never use up in a lifetime.)
Did you test yours yet? Can I toss my cell phone?
Secret confession: I finished assembling them 6/29 but haven't applied power yet. I've got BIG BIG plans. But better hang on to your cellphone for a few more days, just to be safe.
http://www.qrparci.org/fdim
Aw c'mon, at least test the receiver if you don't want to fire up the tx. Rx sounds surprisingly good in these videos.
http://www.ebay.com/itm/Vintage-Telegraph-Key-Switch-J-37-Key-and-plug-assembly-9-Morse-Code-Ham-Radio/142036472944
I'll also dig out my WB4VVF Accukeyer. I loved building and using that! Might make a nice BS-1 project.
