Pnut issue with WMLONG instruction — Parallax Forums
Hi Chip
I've encountered an issue with Pnut handling the WMLONG instruction.
The docs show wmlong as
CCCC 1010100 11I DDDDDDDDD SSSSSSSSS        WMLONG  D,S/#/PTRx
If I try to use the pre/post modifiers or scaled index options on PTRx Pnut generates an error.
	wmlong	b2,ptra++	'Error - Expected an assembly effect or end of line
	wmlong	b2,ptra		'OK
    I'm glad you discovered this. I'll be able to look at it this evening. I think I just used the wrong operand type for the WMLONG mnemonic.
