Power issue with the BS2 controller
I figured out why my BOE board was only running .02 of an amp. Turns out that the BS2 can only send an I/O of .02 amp. So my question is what can I do to fix this? Can I modify the BS2 or could I just buy a new stamp controller. And if I should buy a new controller then what one should I get. Forgot to say, I am, if I can from any stamp controller, wanting to draw around 2 amps from the I/O on the main board.
The board requires ~85 mA for power, but that isn't sourced from the I/O pin. The I/O pin drives a transistor, which safely switched the higher current load of the relay coil. Likewise, a diode in the circuit protects the I/O pin from damage due to inductive kickback from the relay coil. These types of considerations would need to be made on virtually any microcontroller.
