HB-25 has PWM pin high?
Hi,
I am not sure why when I measure between B and W pin on of my 2 HB-25s, I get about 4.75 and 4.78 volt. I believe the input port should not have any voltage. Do I miss anything here?
Thang
Thang
I'm not sure what you're asking.
What sort of microcontroller are you using?
I normally control my HB-25 controllers the same way I control a CR servo.
I think you need to actively drive the HB-25 signal pin. I wouldn't assume any pull-up on the line is strong enough to use it in an open drain configuration.
