serial cog loader — Parallax Forums
serial cog loader
This is so simple I couldn't believe it myself:)
And if it weren't for Rayman's work and Chip's loader, I would never have seen it!!
Thanks guys.
getSerialobj
               call    #rcv_char
               mov whichcog,rx_char
               call    #rcv_char
               setbyte numbytes,rx_char,#2
               call    #rcv_char
               setbyte numbytes,rx_char,#1
               call    #rcv_char
               setbyte numbytes,rx_char,#0
               wrfast  #0,#0
.nextbytes     call #rcv_char
               wfbyte rx_char
               djnz numbytes,#.nextbytes
               coginit whichcog,##0
		ret
the test object is the compiled version of this
dat
		orgh	0
' blink
		org
blink		cogid	x		'which cog am I?
		setb	dirb,x		'make that pin an output
       		notb	outb,x		'flip its output state
		add	x,#16		'add to my id
		shl	x,#18		'shift up to make it big
		waitx	x		'wait that many clocks
		jmp	#blink		'do it again
x		res	1
the loader expects a byte containing the cog number, then three bytes representing the byte count ... and then the raw output of the obj file. I don't stop the cog first... so if you want you can get all of the empty cogs blinking by repeatedly loading the same file.
Makes me happier than.... you know:)
  • rjo__rjo__ Posts: 2,114
    On the computer side of things, I have Processing 3 handling the file.
    public void obj2serial() {
      // Open a file and read its binary data
      String path = "C:/Users/Public/p2/all_cogs_blinkexp.obj";
      byte obj[] = loadBytes(path);
      myPort.write(115);
      myPort.write(14);   //which cog
      int objbytes = obj.length;
      byte tempbyte=byte(objbytes >> 16 & 0xff) ;
      myPort.write(tempbyte);
      tempbyte=byte(objbytes >> 8 & 0xff) ;
     tempbyte=byte(objbytes & 0xff) ;
      // Print each value, from 0 to 255
      for (int kya = 0; kya < obj.length; kya++) {
        // bytes are from -128 to 127, this converts to 0 to 255
        myPort.write( obj[kya]);
        print(obj[kya]);
      // Print a blank line at the end
      println();
      println(obj.length);
