Cluso's P8XBlade2 - Tiny P8X32A Propeller Development Board - now US$18
The P8XBlade2 is the first member in my latest family of tiny Propeller Based Microprocessor boards.
Features:
•PCB 0.78"x1.28" (19.8x32.5mm) 1.0mm thick Blue ENIG (gold finish)
•P8X32A Parallax Propeller Microprocessor
•12MHz crystal (96MHz clock frequency)
•EEPROM 64KB with WE link (preprogrammed)
•microSD socket (preprogrammed microSD card optional extra) on pins P12..P15
•All 32 I/O pins, Reset, 5Vin, 3V3 out and Gnd brought out to 0.1" pitch pads
•Onboard 3V3 voltage regulator
•Onboard (linkable) transistor reset circuit
•Onboard series resistors (linkable 0/68R/136R) and 3V6 zener diode protection on both P30 & P31 lines
•Requires 5VDC Regulated power
•Optional (free) PropOS (propeller operating system)
The EEPROM is pre-programmed with code to boot from the microSD card (user supplied) which will normally contain some form of operating system such as my free PropOS.
It also works with a cheap USB-TTL CP2102 using the linkable transistor reset circuit as an alternative to the PropPlug. +5V power can be provided by the USB-TTL board.
The P8XBlade2 can be used as the basis of any Propeller Development System.
Together with a microSD card formatted with FAT32 and loaded with my free PropOS (Propeller Operating System with similar commands to the old PC DOS and CPM), the Prop will boot into PropOS, or run a user program, without the need for an expensive PropPlug.
P8XBlade2 Cost...
US$18.00 (without microSD card)
US$25.00 (including microSD card with PropOS) ask for price as SD cards have increased for larger size
US$4.00 Packing & Post via Unregistered Airmail Postage from Australia.
Please allow up to 28 days although it usually takes about 14 days to most countries.
Any import duty and taxes, if applicable, are to the purchasers account.
Payment by PayPal to: cluso@clusos.com
PropOS is available for free download
Postedit: Correct SD pins
Postedit: 12 Jun 2019: Latest files here...
http://forums.parallax.com/discussion/comment/1471758/#Comment_1471758
Features:
P8XBlade2 Cost...
Having trouble here...
Win7 and IE10 + Firefox do not have the "attach" option when editing this post. They do on the first post.
Neither does Win10 and Edge
I noticed your web site is down. Updates going on?
Thanks.
Perhaps I was modifying my website at the time - should be good to go although I am in the process of rewriting it.
Here is a direct link to the new section including the P8XBlade2...
http://p8xblade2.clusos.com/
Here is the output from PropOS...
Note that there are additional files that I use to run ZiCog/CPM on RamBlade. (I use the same microSD card)
Here are the PropOS files...
_os_v080_20151215_P8XBlade2.zip has the files required in the root directory on the microSD card FAT16/32 directory.
_os_v080_20151215_P8xBlade2(source).zip has all the files required to build PropOS including the compiler Homespun.
Looks like the website is back up.
So tiny, so cute!!
Happy New Year to me!!
Edit: The answer is, "no". However, I forgot to mention in my PayPal payment what it was that I wanted. I assume you can probably figure it out. :-)
This was a prototype and there will not be any more of these.
Essentially they are a P8XBlade2
* except the microSD is on pins P8..P11
* the processor section is extended to add a microUSB connector
* the pinouts P25...GND are now each side rather than across the board
* there is a prototype area that includes pinouts for Raspberry Pi and Arduino footprints
* the pcb is Blue HASL
Note to use the microSD it is required that part of the Raspberry Pi interface pins be cut out. There are a couple of NPTH holes to help with this.
The P8XBlade2P (P=Prototyping Board) due January will be an exact P8XBlade2 replica (no microUSB) plus the prototype area with Raspberry Pi and Arduino footprints.
CpuBlade7 Cost...
US$27.00 (including microSD card with PropOS)
Specify if you want the microUSB fitted or not - same price.
Does that mean you have USB operating on P1 ?
(inside spec ?)
I'd like 2x blade2, 1x blade7 and one SD (just so I have a master).
Thanks!
Available from Alice1101983 on eBay for US$1.45
http://www.ebay.com/itm/6Pin-USB-2-0-to-TTL-UART-Module-Serial-Converter-CP2102-STC-Replace-Ft232-Module-/400565980256?hash=item5d4397cc60
DO NOT CONNECT the 3V3 as its an output on both boards and the CP2102 CANNOT supply sufficient current anyway.
This interests me very much- I see....
Any idea what the postage would be to uk?
How do we order- cant see an order form on website so- pm and paypal?
I think $16 would just about slip under the UK customs radar - I don't mind paying the UK tax, its paying as much again to have the postie collect it!!!
Dave
Same postage to all countries (I will cover any variations) although some countries have higher risk of theft
Pay via PayPal and send me an email please (or just include a note with PayPal).
Edit: fixed.
I think the price is great!!
http://www.ebay.com/itm/6PIN-USB-2-0-to-UART-TTL-Connector-Module-Serial-Converter-CP2012-6pin-Cables-Y-/281724117017?hash=item419810e019:g:zowAAOSw~gRVgSiH
I posted a link to the one I used a few posts ago.
But, uh... fellow Americans, this embarrassing. Except for Parallax, we've got slim pickins. Even the RoboProp (not a contender for cheapest, but it gets extra points for its Pi header) is from Canada.
With DIP Props having been on backorder for so long, Cluso new board is a godsend.
Wonder what the chances are for an SX-48 version of this board? Maybe I'd be the only customer.
Maybe you could ask on the forum how many would be interested.
