PASM and gcc-asm syntax difference
macca
in Propeller 1
Hi,
I'm writing a driver source using gcc-asm instead of spin/pasm and I found that there is a little syntax difference:
With spin/pasm, if I write:
It works and writes the longs readed from hub memory to the location var_base and var_base+1, however the same code compiled with gcc-asm doesn't work, I think it takes only the first part (var_base) and ignore the addition and all results are written to the same location.
The obvious fix is to explicitly name the destination locations, however I wonder if this is a known issue, or there is a different syntax to do the same?
rdlong var_base, ptr add ptr, #4 rdlong var_base + 1, ptr
Also, this stuff has been changing in recent versions of PropGCC, so it will help if you can tell us exactly which version of propeller-elf-as you are using.
In my source I have ".cog_ram" and ".compress off" directives already.
The gcc version is:
This does require a more recent version of the binutils package than the one that comes with SimpleIDE. In fact PropGCC has changed a lot since the 1.0.0 release, but for whatever reason SimpleIDE is not being updated with new versions. You can build it from source, of course (David Betz has a nice top level repository for this at https://github.com/dbetz/propeller-gcc). I think David Zemon has recent PropGCC binaries available from his PropWare page (look under "Useful Links" on http://david.zemon.name/PropWare/).
Just to clarify, in my source file I have the following header:
I've fixed that, and builds done after today should have .pasm working correctly.
Thank you all.
