SX-48 Single sided board in Eagle.
LoopyBytelooseLoopyByteloose Posts: 12,537
edited 2015-02-10 - 02:52:07 in Microcontrollers
Here are a set of SX-48 Eagle files, board and schematic, plus a image PDF and a transparency PDF.
As was done with my SX-28 images, this is intended for DIY construction at home.
The main thing is that I have worked out how to get the VIAs as jumpers to work in routing.
Look at the next posting for the files. I had to revise these due to some obvious errors. I removed the bad files and now you have super squirrel.
Hwang Xian Shen, Puddleby-on-the-Marsh.
All things considered, I can live and thrive without Microsoft products. LINUX is just fine.
    edited 2015-02-09 - 08:16:15
    Here are the files. Sorry about all the jumping around.
    I am hoping to follow up with this as a 4X board in a PDF.
  • SXleeSXlee Posts: 47
    edited 2015-02-09 - 14:25:27
    Nice! ......... but is the super squirrel for SX-28 or the SX-48 ;-)
    Well, this thread is SX48. So I guess that is where the squirel belongs. The truth is that I had to delete four files that were bad and it seemed that the attachment process wouldn't let exit with zero files... so I included one of my collected jped images.
    Do we now have an SX-48 mascot? I suspect that somebody owns that image.
    PLEASE CHECK THE PDF IMAGE IS ACTUALLY THE CORRECT SIZE before you go through the board making process. I do try to make sure, but printers and images be tricky. I suggest you print in the highest resolution (dots per inch) possible. What you see in PDF will be converted by what the printer is set to deliver.
