How do you find the hub address of initialized data? — Parallax Forums
pedwardpedward Posts: 1,642
edited 2013-04-14 22:11 in Propeller 2
If I include initialized data in a SPIN program (PASM at this point), how do I find the hub address of that initialized data? I looked at Chips ROM monitor code and he takes some very elaborate steps to statically calculate the offsets and store them as immediates, but I want to know the right way of finding the hub address of a variable.
  • potatoheadpotatohead Posts: 10,254
    edited 2013-04-14 14:26
    Do you mean the @operator?
    What I do is look at the object listing in Pnut, then add the load address to it, which is usually $e80, but can be $1000, or something else
    TYPE: 4B   VALUE: 013402B8   NAME: XMIN
    TYPE: 4B   VALUE: 013802BC   NAME: YMIN
    TYPE: 4B   VALUE: 013C02C0   NAME: XMAX
    TYPE: 4B   VALUE: 014002C4   NAME: YMAX
    TYPE: 4B   VALUE: 014402C8   NAME: MAX_COMPUTE
    TYPE: 4B   VALUE: 014802CC   NAME: COLOR_MUL
    That is from the object listing for the fractal thing I just did. The VALUE: field is two words. For YMAX, these are 0140 02C4. The lower word is the HUB address, starting from 0. The upper word is the address relative to the ORG last issued.
    So then, YMAX lives at $0e80+$02c4 absolute HUB address.
    The "@" operator generally just needs the load address added to it for things to work nicely, if you've not padded the code with an array.
    IMHO, the monitor being in low RAM warrants and ORG and OBJ operator... or some other thing that specifies an address offset to work with.
    There is a more detailed explanation aimed at using the monitor to modify values, start COGS, etc... You can find that document here: http://forums.parallax.com/attachment.php?attachmentid=98587&d=1357887830
    edited 2013-04-14 19:27
    pedward: If you fill the $e80 are with 0's and start your cog code at $e80, or fill to $1000 and start your cog code there, and use p2load to load it with the -s and optonally -h modifiers, you can do a straight @label. I do this throughout my P2 debugger so take a look there.
  • pedwardpedward Posts: 1,642
    edited 2013-04-14 20:23
    Well, I did get it to work this way:
    		setptrb	buffer
    		mov	buf, #fox
    		shl	buf, #2
    		add	buf, cogbase
    		call	#print_string
    print_string
    		setptra	buf
    :loop		rdbytec	c, PTRA++	wz
    if_nz		or	c, color
    if_nz		wrword	c, PTRB++
    if_nz		jmp	#:loop
    print_string_ret	ret
    cogbase		long	$E80
    fox		byte	"The quick brown fox jumped over the lazy dog.",0
    If you compile like this...
    CON
      _ROM_SIZE     = $E80                          ' length of ROM (i.e. the start of Hub Ram)
      _RESERVED     = $180                          ' reserved for drivers $00E80-$00FFF
      _COG_BASE     = _ROM_SIZE+_RESERVED           ' cog code entry
      _clkmode = xinput
      _xinfreq = 60_000_000
    ''============================[ DAT ]============================================================
    DAT
                    byte    0[_ROM_SIZE]            ' filler for ROM space $e80
                    byte    0[_RESERVED]            ' filler for reserved HUB space $180
    '$01000
                    org     0
    entry
                    setptrb buffer
                    mov     buf, ptrfox
                    call    #print_string
    print_string
                    setptra buf
            if_nz   or      c, color
            if_nz   jmp     #:loop
    print_string_ret
                    ret
    fox             byte    "The quick brown fox jumped over the lazy dog.",0 .
    ptrfox          long     @fox                   ' the hub address of string1
    and use p2load like this...
    p2load -v -s xxxx.obj -h -T
    p2load (-s) skips the first $e80 longs, and starts cog execution at (-h) $1000 hub.
    This method saves worrying about the $e80 offset.
    If you remove the -h, then execution will start at $e80, so delete the line allocating the
    byte 0[_RESERVED]
