carry bit after max instruction
ersmithersmith Posts: 3,812
edited 2013-03-20 - 13:48:29 in Propeller 2
Has the behavior of the carry bit been changed for the max and min instructions? It sure seems that way, unless I'm missing something. I tried this simple program:
#include <stdio.h>
#include <propeller.h>
// returns the carry bit after max a,b
extern _NATIVE int testmax(int a, int b);
__asm__(
"   .section .kernel    \n"
"    .global _testmax    \n"
"_testmax               \n"
"    maxs  r0,r1 wc      \n"
"    mov      r0,#0         \n"
"    muxc  r0,#1         \n"
"_testmax_ret           \n"
"    ret                 \n"
void runtest(int a, int b) {
    int c = testmax(a, b);
    printf("testmax(%d, %d)=%d\n", a, b, c);
void main() {
    runtest(1, 2);
    runtest(1, 1);
    runtest(2, 1);
On P1 I get as output:
testmax(1, 2)=1
testmax(1, 1)=0
testmax(2, 1)=0
but on P2 I get:
testmax(1, 2)=0
testmax(1, 1)=0
testmax(2, 1)=1
FlexGUI, a GUI for programming the P1 and P2 in Spin, PASM, BASIC, and C.
Help support its development at Patreon or PayPal.
  • cgraceycgracey Posts: 12,171
    edited 2013-03-20 - 08:53:13
    It HAS changed. I believe I made the MINx/MAXx instructions return 1 in C when D had to be changed. I haven't documented this yet, so I'll need to investigate, myself. I looked at the Verilog, but it wasn't clear to me, as the main adder is the most convoluted of all sections.
  • ersmithersmith Posts: 3,812
    Thanks for the reply! We were using the old behavior in the PropGCC float code. It's not a big deal to change it (it just means adding a "cmp" instruction) but it did kind of surprise me :-).
    I guess there's an argument to be made for either behavior. The P1 one was convenient for some things (carry was set if at the end the output D is different from S) but the P2 way is logical too (carry is set if D had to change). At any rate I'm sure it's too late to make any changes, except to the documentation to point out the difference.
    Eric
