Locating & Identifying propeller chip via USB
MacTuxLinMacTuxLin Posts: 791
edited February 2012 in Propeller 1 Vote Up0Vote Down
Hello All,
I'm rather new here & hope some kind soul could direct me to a link or note to read up on how an app (Java or any desktop app) could locate, identify & connect to a propeller-chip board if it is connected via the USB. I'll be using SPIN on the propeller and I think I'll need to allocate Pin 30 & 31 for polling but how do I use, say Javax.comm, to connect to propeller?
Thanks in advance.
Kenichi
  • 5 Comments sorted by Date Added Votes
  • RaymanRayman Posts: 8,326
    edited April 2010 Vote Up0Vote Down
    I think the Propellant library can do that... I believe there's a dll interface for it.
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
    My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
    Prop Info and Apps: http://www.rayslogic.com/
  • MacTuxLinMacTuxLin Posts: 791
    Rayman, thank you. Just downloaded the Propellent.
    Kenichi
  • obrienmobrienm Posts: 65
    edited February 2012 Vote Up0Vote Down
    Hi,
    The standard javax.comm library originally developed for linux but extended for win32 works fine for me, no resets. The library will not work on a 64 bit JVM but I am able to control multiple quickstart boards simultaneously from a single java process after first reloading them all using propellent in an Ant script.
    see http://javahardware.blogspot.com/2010/11/led-display-board-driven-by-javaxcomm.html
    and the original posts
    http://forums.parallax.com/showthread.php?119851-Writting-propeller-data-to-a-file-on-my-PC&p=879906&viewfull=1#post879906
    http://forums.parallax.com/showthread.php?109333-HowTo-Single-host-computer-and-multiple-propeller-serial-comm-and-programming&p=775612&viewfull=1#post775612
    http://forums.parallax.com/showthread.php?137636-Quickstart-Board-reboots-when-PC-GUI-program-starts-and-stops&p=1071154&viewfull=1#post1071154
    http://forums.parallax.com/showthread.php?132944-Java-comm-and-basic-stamp
    Ant picks up extra verbosity from propellent
    <project name="grid" default="reload.all">
    <property name="spin.file" value="lcas_20120129_grid_f_input.spin"/>
    <property name="EEPROM" value="/EEPROM"/>
    <!--property name="EEPROM" value=""/-->
    <target name="reload.all" description="reload entire grid">
    	<antcall target="reload">		<param name="port" value="23"/>	</antcall>
    	<antcall target="reload">		<param name="port" value="48"/>	</antcall>
    	<antcall target="reload">  		<param name="port" value="47"/>	</antcall>
    	<antcall target="reload">		<param name="port" value="46"/>	</antcall>
    </target>
    <target name="reload">
      <apply executable="propellent">
    	<arg value="/PORT"/>
    	<arg value="comm${port}"/>
    	<arg value="${EEPROM}"/>
    	<fileset dir=".">
    		<patternset>
    			<include name="${spin.file}"/>
    		</patternset>
    	</fileset>
      </apply>
    </target>
    </project>
    propellent output
    G:\_dev\active\_parallax\20111211_lcas_qs>ant
    Buildfile: build.xml
    reload.all:
    reload:
        [apply] &#9786;EVT:501-Compiling: FULLDUPLEXSERIAL
        [apply] &#9786;EVT:501-Compiling: LCAS_20120129_GRID_F_INPUT
        [apply] &#9786;EVT:502-File(s) compiled successfully.
        [apply] &#9786;EVT:503-Checking COM23
        [apply] &#9786;EVT:505-Propeller chip version 1 found on COM23.
        [apply] &#9786;EVT:506-Loading RAM
        [apply] &#9786;EVT:507-Verifying RAM
        [apply] &#9786;EVT:508-Programming EEPROM
        [apply] &#9786;EVT:509-Verifying EEPROM
        [apply] &#9786;INF:451-Success.
        [apply] &#9830;
    reload:
        [apply] &#9786;EVT:503-Checking COM48
        [apply] &#9786;EVT:505-Propeller chip version 1 found on COM48.
        [apply] &#9830;
    reload:
        [apply] &#9786;EVT:503-Checking COM47
        [apply] &#9786;EVT:505-Propeller chip version 1 found on COM47.
        [apply] &#9830;
    reload:
        [apply] &#9786;EVT:503-Checking COM46
        [apply] &#9786;EVT:505-Propeller chip version 1 found on COM46.
        [apply] &#9830;
    BUILD SUCCESSFUL
    Total time: 22 seconds
    thank you
    /michael
    @Michael,
    This is cool! Its funny, when you needed something its always hard to find but they seems to jump right in front of you when you don't. -_-" .... I've actually detoured to VB.net since then but guess its time to re-look at it again (maybe in June).
    Kenichi
