One-Buck Ultrasonic Sensor
10/15 Update: 88 cents. That's just crazy. http://www.ebay.com/itm/New-Arduino-Ultrasonic-Module-HC-SR04-Distance-Sensor-Measuring-Transducer-/181849383810
08/14 UPDATE: Renaming the thread One-Buck Ultrasonic Sensor due to Price Drop: http://www.ebay.com/itm/New-Arduino-Ultrasonic-Module-HC-SR04-Distance-Sensor-Measuring-Transducer-HE-/400756229697
End Update
11/26/12 UPDATE: After a year, I finally changed the thread title from Four-Buck to Two-Buck: http://www.ebay.com/itm/New-Arduino-Ultrasonic-Module-HC-SR04-Distance-Sensor-Measuring-Transducer-Hot-/271040857767?pt=LH_DefaultDomain_0&hash=item3f1b4b46a7
END UPDATE
http://www.ebay.com/itm/270810920267
I lied. $3.95 w/free shipping. Prices on these sensors have been plummeting recently and this is a new low.
I received several of these today, which I paid $4.50 for on October 29. They are pictured and described as SRF-04, which I have used before. 4 pin units. Not PING quality, but very nice. Main bad thing is that they take 2 I/O pins. One trigger, one echo. PING uses just one.
What I received today are newer 4-pin SRF-05 units. Never used these before, and the only info I have found in 10 minutes of searching is at
http://www.robot-electronics.co.uk/htm/srf05tech.htm and
http://www.acroname.com/robotics/info/articles/devantech/srf.html
which implies that these can be used with just one pin, like a PING.
The pinouts on mine are labeled differently than either of these. Mine are labeled:
Vcc---Trig---Echo---OUT---GND so these are some variant or knockoff. I hooked one up to a BS2 tonight using 2-pin mode and it worked flawlessly. I'll request info from the seller about the OUT pin, might take a day to get a reply.
With luck, I'll find out that I can tie the OUT pin to ground and get to one pin mode.
Without any reply or luck, I may tie the OUT pin to ground and release the magic smoke.
So right now, I can't say if they function on one pin, or that the seller will continue to ship 05 units instead of 04's, but they are quite a bargain either way. I just ordered some more. I'm a gamblin' man.
End Update
END UPDATE
Was dispatched on day 8, and I'm still waiting. I've never used an ultrasonic sensor, and I want to experiment with security systems, does not seem enough PIR sensor.
Thank you.
Now if they start shipping a different version like the SRF05 and it doesn't provide the same results then it is going to upset some people that expect the HC-SR04 modules.
Robert
Just to put a fine point on it, the eBay sellers are providing Chinese knockoff boards, not the Devantech SRF-04s and SRF-05s shipped from the UK. The Devantech SRF-05s have similar specs as the 04s, but can use 1- or 2-pin trigger and echo.
Alex's control board for the Leaf allows for all kinds of variations, so even if someone uses (say) a single-transducer like those from Maxbotics it shouldn't really impact things.
-- Gordon
-- Gordon
I was also thinking that the OUT pin could be a digital output, triggering at some preset distance. I have seen 4-pin lookalike modules from Sure electronics that only had a digital output like that. I need specs and or more time to play.
Just to clarify things it was one of the cheap $4 knock off versions that was DOA. I haven't heard anything bad about the real SRF04 modules. You get what you pay for. The cheaper ones may work ok but you may get a substitution you weren't expecting and perhaps there may be a dud mixed in.
Robert
Besides, both Gerry in the UK and Steve (at Acroname, Gerry's US distributor) would replace the DOA in a heartbeat.
-- Gordon
http://www.ebay.com/itm/Ultrasonic-Wave-Distance-measure-Module-Ranging-Sensor-/190548468478?pt=LH_DefaultDomain_0&hash=item2c5d92e2fe
The ads are made to look like the real down load link.
Here is the real file.
Ultrasonic.zip
http://www.emartee.com/Attachment.php?name=41365.pdf
Dat's my dawg!
I gotta figure a way to get a dime per sale off all my Ebay recommendations. You tentatively owe me 40 cents. I'm keepin' track, Pal!
My sensor is HY-SRF05 (pictured say HC-SR04), and tested it with the object of Parallax "ping.spin", with some modifications because the sensor uses two pins.
Measured with precision, but after 102 inches (2.5908 meters), usually lose the range.
Is it normal?
On the eBay page says: Distance range: 2cm-450cm (4.5 meters).
Thank you.
It also depends on the surface, maybe if we use a larger barrier object sensor can see.
I am using an object 14 inches diagonal, as a barrier.
Parallax sensor operates in the range that promise?
The quality looks ok on them but there are a couple important differences worth mentioning. First, the spacing of the transducers is wider than the Standard SRF-04 modules. That may cause problems for those that use a bracket or mounting that needs the sensors in the normal location. Second the mounting holes are very tiny. I'm used to the SRF-04 and the Parallax PING that can use a #4 screw for mounting. For the knock off modules that isn't going to work. You'll need a smaller #2 screw, double faced tape, or glue.
I think for my main projects I will keep on using both the Devantech modules and the Parallax PING sensors. For odd projects these cheap ones will probably work just fine and I'll be able to find a use for them somewhere.
Robert
@RobotWorkshop It =kinda= looks like there might be room to drill out the mounting holes just a bit. I'll try one tomorrow.
FAIL.
-- Gordon
Sorry Erco, I had come across these on my own surfing ebay before reading your post. No 2% on this one.....
Heck, mine are exactly $100 less. Plus free shipping!
Anyway all the parts for my next build have arrived, so it's time to get cracking.
