even paraty setup
stefstef Posts: 169
edited September 2011 in Propeller 1 Vote Up0Vote Down
Hi
I always use the Fullduplex.spin for serial comunication. It is working fine. Now I need to interface to a device that has specification 2400,8,E,1.
The baud rate is not a problem to set up.
How do I specify the E (Even parity)??
Stef
  • 9 Comments sorted by Date Added Votes
  • AribaAriba Posts: 2,004
    edited September 2011 Vote Up0Vote Down
    Hi Stef
    Search for "FD_Serial_Conf.spin" in the forum, this object should do what you want.
    Andy
  • Mike GreenMike Green Posts: 22,335
    You can use FullDuplexSerial by computing the parity yourself and adding it into the 8-bit value you're sending. For transmitting a 7-bit character CH with even parity, do:
    FDS.tx((CH & %1111111) | (((CH<<1) ^ (CH<<2) ^ (CH<<3) ^ (CH<<4) ^ (CH<<5) ^ (CH<<6) ^ (CH<<7) ^ %10000000) & %10000000))
    On receive, you'd do a similar calculation, but compare the result with what was actually received.
  • stefstef Posts: 169
    Tanks to all
    I'm going to try it out.
    Stef
  • Heater.Heater. Posts: 17,975
    Wait a mintute. I thought 8,E,1 meant 8 Data bits plus 1 parity bit plus 1 stop bit. So putting the parity bit into the top bit of the 8 bits of data does not do what you want.
  • Mark_TMark_T Posts: 1,536
    I think 8, E means 8 bits including even parity, 8+parity would mean 9 bits...
    Ok. I'm confused. If the parity bit is in the 8 data bits would that not really be 7 data bits plus 1 parity bit or "7,E,1"?
  • kwinnkwinn Posts: 7,007
    Heater is right. 2400,8,E,1 would be 2400 baud, 1 start bit, 8 data bits, 1 even parity bit, and 1 stop bit for a total of 11 bits.
    In science there is no authority. There is only experiment.
  • BEEPBEEP Posts: 58
    "For example, a frame that uses seven data bits, even parity, and one stop bit is abbreviated 7E1, and one that uses eight data bits, no parity, and one stop bit is abbreviated 8N1."
    http://www.freeopenbook.com/pc-hardware-nutshell-2/pchardnut2-CHP-22-SECT-1.html
