Parallax USB-RS232 converter (DIY ALDL ODB1 cable)
Hi,
I am new here at the forums. I am posting here because of a project I have been working on. Long story short, I am making a ALDL OBD1 cable to connect my laptop to my 92 blazer. I found the parallax USB to serial converter and decided to use that as the heart of my cable. In addition to the converter I used a ALDL to RS232 circuit. Here’s what I have so far...
I made the OBD1 connector and the ALDL converter circuit for the project. Here’s the schematic for the ALDL to RS232 converter...
So, can’t get a connection to the program I am using, “TunerproRT”. I need to take this one step at a time and would like to know if the circuit I have made will work with the parallax converter. Any other ideas or information would be helpful. Redesigning the whole thing is always an option.
Thanks~
Thanks~
I guess you should try the ALDL to RS2332 on a computer that has an RS232 port to verify your build of that part is working properly.
There are several free RS-232 terminal mode programs available in Windows, OS-X, and Linux, don't buy anything. Parallax provides one for at least Windows.
After you are sure that portion is okay, then insert the USB-RS232 and use the laptop with the same RS-232 terminal mode program.
http://winaldl.joby.se/aldlcable.htm
which circuit did you use? Also did you use R3 on your circuit?
thanks
