DPDT relay with off postion?
dbc1218dbc1218 Posts: 33
edited February 2007 in Robotics Vote Up0Vote Down
Does anyone know where I can get a DPDT (double pole double throw) relay with an off position? I know you can get switches like this with a center off position but didn't know about a relay. I want to use it for a project, using a remote control car that has differential steering, to control one of the two motors. I don't even know if something like this is made but maybe one of you guys have seen it.
  • 6 Comments sorted by Date Added Votes
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 21,412
    edited February 2007 Vote Up0Vote Down
    How about two DPST relays instead? You'd need two actuation signals anyway for a center-off relay. 'Might as well just use two regular relays.
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
  • Bruce BatesBruce Bates Posts: 3,045
    dbc1218 -
    Such DPDT C/O relays have two coils. One coil actuates the armature in one position or direction, and the other actuates it in the opposite position or direction. If neither coil is actuated, the relay self-centers for an "OFF" position.
    More information can be provided, if you provide some specifications. The primary concerns here are voltage, amperage and mounting.
    Bruce Bates
    <!--StartFragment -->
  • crgwbrcrgwbr Posts: 614
    You could also just use 4 spst relay in an H-bridge pattern.
    NerdMaster
    For
    Life
  • dbc1218dbc1218 Posts: 33
    You guys are right with the multiple relays and you would need the same number of control signals. I think thats going to be the easiest way to go. Thanks for the help.
  • slamerslamer Posts: 52
    If you looking for RC switches. these little guys work great. We use them in RC combat robots all of the time.. They accept standard PWM signals from a receiver or you can control them with a Basic stamp2. From what you posted you probably could use the RCE 220 to control the on/off direction of a motor. You can wire it to work as an H-bridge with a couple of jumpers.
    http://www.robotcombat.com/marketplace_teamdelta_rc.html
    These fine products are made by Team Delta...
    http://www.teamdelta.com/
    undefinedundefinedundefinedundefinedSteven Kirk Nelson (slamer)
    Team K.I.S.S
    Build Safe, Build Mean, Build Strong!
