The Pololu Micro Dual Serial Motor Controller Is Back — Parallax Forums
Lauren DavisLauren Davis Posts: 313
edited 2007-01-17 01:50 in Announcements
The Pololu Micro Dual Serial Motor Controller Is Back - Now RoHS Compliant!·- Pre-Order (ships Friday, 1/19/07)
· ··············· attachment.php?attachmentid=45049
Using one serial output from the BASIC Stamp module, this motor controller can independently set each motor to go forward or backward at any of 127 speeds. To control additional motors, you can connect multiple motor controllers to the same serial line. The Pololu controller supports a low range of voltages and comes pre-assembled. It measures only .9 x .45 inches and is compatible with all BASIC Stamp microcontrollers. In addition to the Pololu controller, you will need a BASIC Stamp module, programming board and motor(s).
For more information, or to purchase the Pololu Micro Dual Serial Motor Controller #30052, click on the following link http://www.parallax.com/detail.asp?product_id=30052. ·
Lauren Bares
Marketing Manager
916-624-8333
lbares@parallax.com
Post Edited (Lauren Bares (Parallax)) : 1/17/2007 2:12:55 AM GMT
450 x 373 - 73K
64 x 100 - 7K
