DS1307 for Propeller — Parallax Forums
NewzedNewzed Posts: 2,503
edited 2006-06-04 23:23 in Propeller 1
I have come up with a small board - .900x2.000 - for interfacing the DS1307 to the Propeller.· The board has 4.7K pullups on the SDA/SCL pins, a 2-pos header for 5VDC and Gnd, and a 2-pos header for patching the SDA/SCL pins to the Propeller.· The board also has a 1.2 K resistor in series with the 1307 SDA/SCL pins and the 2-pos header.· The square wave output is brought to a pad Where you can solder a wire or install a 1-pos header.· I have attached a layout of the board.· If you are interested please contact me at Newzed@aol.com.
Sid
Sid Weaver
Do you have a Stamp Tester yet?
384 x 189 - 7K
