RESn circuit — Parallax Forums
RESn circuit
NewzedNewzed Posts: 2,503
edited 2006-05-27 15:47 in Propeller 1
Is there any reason I can't use a 2N2222A in place of the 2N3904 in the RESn circuit?· Minimum quantity on the 3904 from Digikey is 600 - not RoHS compliant, I would guess.
Sid
    edited 2006-05-26 22:44
    I don't see why not, however www.mouser.com looks to have plenty of the 2N3904 in stock, and they don't have a minimum order dollar amount like www.digikey.com
    http://www.mouser.com/index.cfm?handler=displayproduct&lstdispproductid=271833&e_categoryid=241&e_pcodeid=51127
  • NewzedNewzed Posts: 2,503
    edited 2006-05-26 22:52
    Thanks, Mike.· If I ordered the 3904 from Mouser I would have to pay the $5.00 minimum plus shipping since that is the only thing I need, and that would make it a pretty expensive transistor.· I'll go with the 2222A since I have them on hand.
    Sid
    edited 2006-05-26 22:56
    Sid,
    www.mouser.com does not have a minimum order charge of $5.00
    I can think of no reason why a 2N2222 would not work in place of the 2N3904.
    I would use what I had on hand.
    Have fun and good luck.
    edited 2006-05-26 23:23
    Mike, I have designed my own board for the Propeller.· It is sort of like the PropStick, except it has an On-Off switch, a 5VDC and a 3.3VDC regulator in tandem, and an RCA connector for the TV object, plus an 8-pos 5VDC bus,an 8-pos Gnd bus, and a pushbutton that can be patched to any pin.· The PB is pulled high by the on-board circuitry.
    Sid
    edited 2006-05-26 23:39
    Sid,
    I'm doing something similar using ExpressPCB, I have 4 Propeller DIPs that need a permanent home!
    My board will have the following:
    1. 3.3 and 5 VDC switching power supply
    2. the discrete programmer, something like this:
    http://forums.parallax.com/showthread.php?p=585009
    3. EEPROM, TV-IO, and IR detector on pins P31-P24
    4. P0-P23 will go to a general purpose header
    When I get done testing all the GPS receivers & antennas I purchased, I'll get back on the ExpressPCB board.
    I'm planning to replace some of my 'one-off' prototype work that I've been doing on: PIC, SX, and AVR with the Propeller.
    Hopefully all former processors that I've been using will be replaced with the Propeller. Only hitch in this scheme is the occasions when a $.50 PIC micro is all that's needed for the final design.
  • ForrestForrest Posts: 1,341
    edited 2006-05-27 01:06
    FYI www.glitchbuster.com/ sells a bag of (12) 2N3904 transistors for $.98 + $1.95 shipping
  • rockin_rickrockin_rick Posts: 32
    edited 2006-05-27 15:31
    Newzed said...
    Sid
    How bout this one:
    www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=34204&Row=90782&Site=US
    2N3904FS-ND - ~186,000 in stock - RoHS not specified - TO-92 - min qty = 1
    Rick
    Thanks, Rick - I finally found it after I had sent me order ibn.· Knew I'd seen it once before but I was using the wrong part number.· Oh, well.............
    Sid
