object symbols accessible from assembly? — Parallax Forums
rokickirokicki Posts: 1,000
edited 2006-05-22 02:25 in Propeller 1
I'm curious why con and var symbols do not appear to be accessible in
the assembly sections. For instance,
var long x ;
dat
rdlong d0, x
I really would expect this to work! Any reason it doesn't? It seems odd
to have all this wonderful facility for declaring main memory storage and
constants, and then to just turn it all off in the assembly section.
(And I understand that var long x declares main memory and not fast
cog memory but still).
    edited 2006-05-22 02:22
    You can pass the addresses of variables to an assembly routine. Keep in mind that addresses in assembly language are 0-511 (longs) with few exceptions. Any HUB addresses have to be in "registers" (COG locations) anyway.
  • SSteveSSteve Posts: 808
    CON symbols are accessible in assembly sections. They are substituted by the compiler before any code is ever sent to the Propeller.
    OS-X: because making Unix user-friendly was easier than debugging Windows
