Could some one please tell me why this scrolling text box doesnt work? — Parallax Forums
Kaos KiddKaos Kidd Posts: 614
edited 2006-05-23 20:02 in Propeller 1
I'v tried everything I can think of, and I just can't see why the textbox doesnt scroll or work right when the text is less then the size of the box...
Just tossing my two bits worth into the bit bucket
KK
    edited 2006-05-20 19:47
    Correct me if I'm wrong, but isn't this
    VGA.STR(Text[noparse][[/noparse]Index])
    supposed to be
    VGA.STR(@Text[noparse][[/noparse]Index])
    Also shouldn't
    HoldChar := Text[noparse][[/noparse]Index + Size + 1]
    be
    HoldChar := Text[noparse][[/noparse]Index + Size]
  • Kaos KiddKaos Kidd Posts: 614
    edited 2006-05-21 15:04
    Hmmmm...
    I had not thought of that... thanks for the insight and I'll give it whirl!
    KK
    edited 2006-05-22 02:15
    Well, that wasn't it...
    It's printing trash...
    I changed the ref's to include @Text[noparse][[/noparse]Index]
    I think it's got something to do with what is acutally created with STRING command, or what VGA.OUT is expecting
    KK
    edited 2006-05-22 02:24
    VGA.OUT expects a character value. VGA.STR expects the address of a null-terminated string. STRING constructs a null-terminated string constant and its value is the address of the string at run-time.
    edited 2006-05-22 15:24
    Mike:
    As I figured out. Hence the VGA.STR call, now follow this: If I remove the [noparse]/noparse from the call, it prints!
    Yes, if I do VGA.STR(@Text), it prints it all out.
    But, if I do VGA.STR(@Text[noparse][[/noparse]Index]), I get "trash" on the screen.
    I understand about the null terminator, that's how I'm setting the length of the string to print.
    HoldChar = the original char, then I set it to null, print it, then reset it.
    The question is simply this: Why can't I start outputing from the middle of the screen?
    Eventually this routine will be included in something that gets its data from a device (like the directory of a SD device or something), which may or may not be be bigger then the scrolling window.
    Oh, and BTW, thanks for helpin me out here...
    KK
  • Beau SchwabeBeau Schwabe Posts: 6,547
    edited 2006-05-23 00:04
    Kaos Kidd,
    I modified your code a little bit, I believe this version is closer to what you are looking for.
    Version 1:   - Initial scrolling solution of modified code
    Version 2:   - Added automatic character padding on either side of main scrolling text
                 - "Title" or non scrolling text can be a null string size.
                 - The main scrolling text can range from 1 character to 255 characters.
                   In other words it can be smaller than the available scrolling window and
                   still scroll from right to left.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 5/23/2006 7:19:20 PM GMT
    edited 2006-05-23 03:21
    Beau:
    Thanks! I would have never thought of the byte command.
    Slick..
    THanks again all!
    KK
    Beau:
    THe new edits are much better... and slicker!
    thanks again...
    KK
